Throwing codes
a quick google search can help you with that.
P0243 Supercharger wastegate solenoid fault.
P0300 Random multiple cylinder misfire
P0452 Evaporative emission control system pressure sensor low
P1133 Bank 1 sensor insufficient switching
P1653 5V Reference (B or 2) Circuit
did you move anything recently on the engine bay? Symptons?
sounds like someone needs just an old fashion tune up
this is your plug and wire locations, in case you mix a wire up.
images
might be a little more serious then that. i have been chasing down certain codes you have listed for a while and haven't been able to figure it out. Lmk how it goes as it might help me out as well lol
the random misfire code could be cause the gaps to tight, open them back up to 45 and see if that helps. with that code at least.
I must have screwed something up last night. New plugs and the only other thing I did was change the gap.
There are some plugs flopping around under the hood. I'm wondering if any of those are supposed to be plugged in?
Possibly, but there must be something causing all this issue, to me just how i think mine is, is more of a electrical issue, his 5V reference is pulling a code, meaning there might be a short somewhere. That 5v reference controls practically all electricals in the car mainly engine. so if that is bad it can throw off the icm which throws off spark and so on. Hopefully it is something easy for him. but depending on what all he did and disconnected or moved will help.
What plugs? you should have all of them connected. post a pic of them.
I'll take pics and post tomorrow. I'm pooped and my "pansy hands" hurt. BWAAAAAAAAAAA!
Thanks for all the help. We'll get it figured out eventually.
OK. So here come the pics of the stuff not plugged in. First, I pulled one of the new plugs to have a look.
Found this just flopping around.....What is it and where should it be?
Why isn't this thing plugged in and what is it?
Found this plug,
And this plug,
My feeling is, that this stuff wasn't needed after all the turbo stuff was added, but I'll need you experts to tell me...........
[/QUOTE
first [pic is a the ait sensor, it would be in the intake tube.
second pic is the egr, not sure why its there, no way its hooked up i bet.
not sure where it goes on a turbo car or if its used really, i just know what it is lol
the round sensor, the egr, its sits on a pedestal and has flex tubes from the lower intake, to the rear exhaust manifold. dont think a plog had the hole for the egr, so it may be there just for looks. if it was unplugged it must be deleted.
