1999 GTP with the common knocking of a spun rod bearing...
OEM bolts are stretch to yield. ARP studs torqued at 80 lbs. Studs were installed when lined honed. ARP recommends line honing when using their hardware.
Is it because people reuse the TTY cap bolts that these engines typically fail shortly after rebuild? Is there a few "must do" things that get missed?
Surely it is possible to rebuild a reliable L67 if the proper steps are taken and the proper materials used, no?
