Question...
Newfie83
Im replacing the Transmission on my 05 GTP This week. Should i replace the Torque Convertor Seal even if it seems ok?? And whats the best tool or way to remove and install this seal.. Thanks
Your new transmission will come with a new/different seal.
If you mean you're rebuilding it, then yes, replace it AND EVERY seal.
Remove it using a seal remover or screwdriver/visegrip.
Ah that makes sense.
A seal costs about $5, I think it's cheap insurance given that you have to drop the tranny to replace it. The axle seals are easy to replace when in place.
Personally, I would DEFINITELY replace it with a good quality OE seal. I would also make sure the snout on the TC is clean and smooth.
