Please Help Traction control ABS
tmull44
I have a 2005 GTP Comp G. Since it had 28k miles on it there has been a problem with the ABS light, Traction Control light coming on. It's been to the dealer MANY times and they usually replace a wheel speed sensor I believe numerous times on every wheel and it lasted no more than a few days. I'm sure this has come up with others and maybe covered here. Anyone?
Thanks
You need to have codes pulled when the light comes on. That will point you in the right direction. Could be wires. Look over all speed sensor wires and check for damage. You could pull the connectors off and clean them and grease them to see if it helps.
But, yeah, codes will help.
