Need help with warning lights!!
91z
Dont know why, but after I start my 04 gtp the traction controll, stability controll and the abs shut off and say they need servicing? Not sure what the heck is going on? Could the bcm for those be bad? And could it also be why my radio has no power to it unless I hot wire it?
The traction, abs and stability lights are probably caused by one or multiple bad wheel bearings.
Is it a stock radio? Have you checked the fuse to your radio?
Ahhh I never thought of that. I have a wheel bearing going out. The radio on the other hand is stock and all fuses are checked and good. I think my lemon has some issues.
