head gasket replacement
ZACH05GTP
I have to do the head gaskets on my 05 gtp. Just wondering if any one has any pointers or tips to make it easier also if the head bolts are reusable or just buy new ones. Thanks
the head bolts are not reuse-able, and while the heads are off have a shop check them over.
id do some tests before just tearing into a head gasket job tho. cylinder compression test, a cooling system pressure test.
and they have another test kit, it tests for o2 in the coolant, via the radiator.
