Digital climate control
try holding driver and passenger buttons down at the same time. display should show 00. then use the driver side dial to change the screen to farenheit. hopefully this works.
All it comes up with is 00 not a way to change it. I had been messing around with it before an caused it to do this
Ok fixed it! Don't know what caused it in the first place but if you unplug connector D7(black wire) on the back of the unit it will go back to Farenheit.
