Daytime running lights problem
royz76108
My lights stay on when the key is out of the ignition. I have to disconnect the battery to solve the problem. Is there any other solution? I have a 2007 grand prix.
Are they staying on indefinitely? How long have they been staying on? Have you checked the settings in the DIC under "Personal Programming Mode?
I found the solution on one of the posts. It was the drl relay. I replaced it and it solved the problem. Thanks to whoever posted that answer. I don't remember who it was. I thought at first that was the problem but I was not sure. About 2 years ago I had a problem with the low beams going out sometimes at night and later on they would come on. I was reading the posts in this forum and again somebody came up with the solution and it was the drl relay. It is #35 in the fuse box under the hood. I have replaced this fuse twice in the last 2 years. The good thing is that the relay has a lifetime warranty at Autozone. If I have to replace it again I think there might be a wiring problem somewhere.
