Thread: I'm gonna cry
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: I'm gonna cry
    Yeah..yeah yeah.. go post pics for people that need them.
  2. #22 Re: I'm gonna cry
    GT Level Member RegalGS98s's Avatar
    NJ
    Sorry for your losses Bill. For the blocked sites, I vote remote into your PC at home in some method. I work in IT, so it's a little easier if I wanted to, but bunch of people use pcanywhere or there's a Microsoft program a co-worker uses, but can't think of the name of it. I don't think anything is required on the work PC.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  3. #23 Re: I'm gonna cry
    That would be great. Alas.. large company with an IT group that has locked almost everything down.
    To give an example, you can't set macro security settings in Excel etc. It's locked to ask you each time. Can't put a USB drive into your pc and transfer anything in either direction. Not even to open a file. Want that ability..it's a special usb drive from IT and they have to grant it access.
    My best bet is to work from home. Have one screen with all the forums up and the other have the VPN gateway into work.
    Best of both worlds and I can wear slippers
  4. #24 Re: I'm gonna cry
    i wish i had that ability. but then i wouldnt work, either.
  5. #25 Re: I'm gonna cry
    SE Level Member 07CurbScraper's Avatar
    A Dusty Place
    Set up an SSH tunnel on your home PC to listen on port 80. I haven't done it personally, but I've heard some have. And I'm sure there's more to it than that.
    I come from a dusty place.
    14.4@98
  1. What you gonna do....
    Last Post: 06-05-2011, 01:12 AM
  2. What's your next mod gonna be ???
    Last Post: 08-25-2008, 10:52 PM
  3. Gonna be in the DFW area......
    By Reptile in forum Off Topic Discussion
    Last Post: 05-16-2008, 01:42 PM
  4. Ok im gonna buy a pcm from zzp
    Last Post: 01-22-2008, 10:33 PM
