Thread: sway rage
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 sway rage
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    So I managed to snap my stock sway bar 2 months ago and it took me a good 8 hours to replace it with the redesigned (solid instead of tube) one. Now today I had an oppertunity to get the car high on a lift for once and inspect stuff. Low and behold the new rubber mounts for the sway bar are already cracking and coming apart.... I can't imagion how bad they are gonna get this winter..... instead of getting mad I'll just look at it as a forced excuse to replace with upgraded poly mounts...
    buyer beware of the rubber that comes with the after market replacement sway bars.... I would have been better off reusing the stock rubber
    I feel better now
  2. #2 Re: sway rage
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
  3. #3 Re: sway rage
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    same **** happen to me
  4. #4 Re: sway rage
    GTX Level Member bandits grand prix's Avatar
    Jul 2010
    connecticut
    how do they snap??
  5. #5 Re: sway rage
    Apr 2011
    South Dakota
    Quote Originally Posted by bandits grand prix View Post
    how do they snap??
    Stock front sway bar is hollow (at least on my 01 it was) and so at the point where they crush the ends so you can bolt it up they always crack. I would show you the picture of mine but im still new here and dont have a good place to host my pics.
  6. #6 Re: sway rage
    Donating User Odi's Avatar
    Chicago South Suburbs
    did you grease the bushings?
  7. #7 Re: sway rage
    Apr 2011
    South Dakota
    [QUOTE=Odi;645643]did you grease the bushings?[/QUOTE
    When I was calling around for prices the dealership mentioned that you should use wd40 so that's what I did..... im assuming you referring to the rubber bushings and not the plastic spacers?
  8. #8 Re: sway rage
    for any suspension bushing i use ruglide or energy suspension grease. i wouldnt wd40 it honestly. since ur going poly bushings (shouldhave done it anyways) get some energy suspension bushings and grease.
  9. #9 Re: sway rage
    Apr 2011
    South Dakota
    Oreillies carry them or do I need to whip out my plastic money and get em online?
  10. #10 Re: sway rage
    Quote Originally Posted by frosty View Post
    any poly bushings will do. i doubt oreilly carries them tho. i bought mine from Energy Suspension Parts Dealer, Specializing in Energy Suspension Bushings Suspension Components.
  11. #11 Re: sway rage
    Apr 2011
    South Dakota
    I just checked and both the local part shops (oreilies and advanced) carry energy suspension and Moog brand performance replacements.... will I feel a difference in any way or are they just better made? I'll be needing them soon judging by what I saw while rotating tires today.
  12. #12 Re: sway rage
    Here's a couple pics of my old sway bar when I replaced it on my 97 GP.... I already have the solid bar on my 01 GTP
    Snorlax strikes again.
  13. #13 Re: sway rage
    Rubber can tear it if adheres to the bar. Keep this from happening by using a little Technical Bulletin trick that GM used in the early 90's on some cars.
    Teflon tape then the grease. It'll help keep them lubricated.
    BTW on that 8 hour time. Not sure how you achieved that, well done. Longest sway swap ever.
    Tricks to help you.
    Lower the rear of your subframe 2 inches for room to get into the bolts. You'll be done in 45 minutes.
  14. #14 Re: sway rage
    Tricks to help you.
    Quoted for the truth... It didn't take me long at all when I did it. Not too many people realize that you can use Teflon tape on a sway bar.
  15. #15 Re: sway rage
    Apr 2011
    South Dakota
    Quote Originally Posted by Ramairgt2 View Post
    Gotta give me credit i did manage to fit it in with a large aftermarket downpipe in the way and not dropping the subframe.... ill stick to engine work. I changed a lower intake gasket in 3 hours the last time i did it.
  16. #16 Re: sway rage
    When you get to two hours or less, lemme know. Til then, I suggest you lower the sub a litle. I've done all these things the hard way too. It's simply not worth the struggle.
  17. #17 Re: sway rage
    GT Level Member RegalGS98s's Avatar
    NJ
    [QUOTE=frosty;646212]
    WD40 swells the rubber so I wouldn't use it for this application. I like Bill's teflon tape idea.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  18. #18 Re: sway rage
    Apr 2011
    South Dakota
    [QUOTE=RegalGS98s;646399]
    I'll certainly be buying a fresh roll of tape along side the new rubbers
  19. #19 Re: sway rage
    mine had that tape on it and i saw it and was like wtf???...then i read the tsb about it and was like ohhhh
    SMGPFC Member #10
  20. #20 Re: sway rage
    The Boss Iceman6669's Avatar
    Jun 2011
    sub'd. I will be doing mine soon and like the tape idea.
  1. Sway bar
    By BuckyKatt in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2010, 09:24 PM
  2. sway bar
    By BoostJunki3 in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2009, 02:38 PM
  3. Rant Rage!
    By GPSims39 in forum The Rant Forum
    Last Post: 06-15-2009, 04:03 PM
  4. road rage
    By nemesis in forum The Rant Forum
    Last Post: 10-27-2008, 04:40 PM
