Thread: Recall 07035 engine fire "warning"
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: Recall 07035 engine fire "warning"
    SE Level Member GrandZero's Avatar
    ohio
    Has anyone ever tryed adding an engine oil cooler? If so what would be good for stopping an oil leak threw threads?
  2. #22 Re: Recall 07035 engine fire "warning"
    impala 9c4's had that IIRC.
    thread sealant.
  3. #23 Re: Recall 07035 engine fire "warning"
    I live here. TLSheff's Avatar
    Yea I'm the parts guy at the local GM Dealership, we still do the "recalls" for the 3800s, goes for all year ranges 97-03 according to service. They usually end up replacing the spark plug wire connectors, 2 connectors that "relocate where the wires sit" (completely ineffective) and the FRONT valve cover gasket, no grommets nore the back which tends to have the most problems (also ineffective).
    DO IT YOURSELF! It takes a few hours with moderate tools and you can get both gaskets and all the grommets cheap. its worthwhile to just do it yourself and solve it.
    Spark Plug Retainers
    - GM# 12132229
    - GM# 88891792
    Valve Cover Gasket
    - GM# 24503937 (need 2)
    Valve Cover Grommets
    - GM# 25534749 (need 12)
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. "Reduced Engine Power" message
    By TomDaBomb2u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2009, 11:00 PM
  3. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
  4. 3.5" tuned PCM running on 3.8" engine
    By 04CompG in forum PCM Tuning
    Last Post: 10-06-2008, 05:14 PM
