Thread: Inner tie rod replacement
Results 1 to 2 of 2
  1. #1 Inner tie rod replacement
    Feb 2014
    Grand Forks, North Dakota
    For ****s and giggles I went to firestone for an estimate to replace the inner and outer tie rod on my driver side. They quoted me $559. $75 for the outer and $95 for the inner and about $240 in labor and another $115 for an alignment. So I hopped on rockauto and bought moog problem solver for $55 and I will be replacing it myself. My question is for those of you that have replaced yours did you stake the inner tie rod housing? Because it's very tight in there for a hammer and punch to bend the flange and it didn't have a pre drilled hole for a stake. I have watched some YouTube videos where guys would use just loctite on the threads because it's impossible to do otherwise.
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  2. #2 Re: Inner tie rod replacement
    Feb 2014
    And for some reason I posted this to the "general grand prix discussion" but some how made it's way to the rant forum but whatever, or I have sausage fingers.
  1. BCM replacement
    By RM686 in forum General Tech Discussion
    Last Post: 06-10-2014, 06:33 PM
  2. Timing Chain/Belt replacement? Tension-er replacement?
    By void33 in forum General Tech Discussion
    Last Post: 02-21-2014, 02:34 PM
  3. VSS replacement
    By rowekmr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2013, 08:37 AM
  4. Replacement Key
    By davidsucg in forum General Tech Discussion
    Last Post: 01-09-2010, 12:13 AM
