Thread: Dealership sold me a modded "Pile" >:(
Page 1 of 3 123 LastLast
Results 1 to 20 of 51
  1. #1 Dealership sold me a modded "Pile" >:(
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    So I bought a 2011 Taurus SHO, with 88k miles on it 15k out the door. On the test drive I knew the car had a minor issue or two, but I worked those into the We OWE , so the dealer would fix. Being a ford, I got the ESP for it.
    I get it home, its not performing or quite running like it should, I hook up torque, and see its running boost, at levels that say its tuned. I go back to the dealer and ask the service department to check to confirm and if so to flash it to stock. ( I don't want to run someone elses mods not knowing whats there) And I was told, they cant flash it back, because its running aftermarket sensors, and a few other mods and that it is indeed tuned. The guy knew this without checking the car.
    So obviously the dealership had knowledge. I NEVER buy modded cars, I don't trust them, and I know usually they've been driven hard. Had I of known I never would have bought the car.
    I also noticed a number of other issues, The Oil pressure light has come on twice, and the transmission slams gears. I bought a Tuned, lemon. And im not even sure that the warranty is valid because its tuned.
    Basically, im stuck with a car running a tune I know nothing about. the only two choices are buy a $400 tuner and have it retuned, or Spending ~300 to have it put back to stock.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: Dealership sold me a modded Lemon >:(
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Or drive that ***** into the service department and demand your money back.
    GPONA #1 Cyber Bully
  3. #3 Re: Dealership sold me a modded Lemon >:(
    GTP Level Member buickman104's Avatar
    NYC
    I would agree. Demand your money back as mods were not disclosed to you. Threaten to lawyer it up as things were not disclosed to you.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  4. #4 Re: Dealership sold me a modded Lemon >:(
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by 04lss View Post
    .....the only two choices are buy a $400 tuner and have it retuned, or Spending ~300 to have it put back to stock.
    Don't forget choice #3, which should be choice #1..... return the car to the lying piece of crap that sold it to you.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: Dealership sold me a modded Lemon >:(
    Sep 2014
    Richmond Virginia
    Well, I talked to a friend, who's mother is a lawyer. He asked her, and ..... yeah that's apparently the least of my options, especially if the warranty is void.
  6. #6 Re: Dealership sold me a modded Lemon >:(
    Jul 2010
    Coquitlam,BC,Canada
    How long have you had this car?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Dealership sold me a modded Lemon >:(
    Wichita
    If you're absolutely stuck with the car your best option is probably to have the car scanned by professional shop. Then research all the codes, maybe join a Taurus SHO forum if you haven't already, and go from there.
    -From what I've learned about cars flashing the PCM on a modded car back to stock could do more harm than good.
  8. #8 Re: Dealership sold me a modded Lemon >:(
    Nov 2013
    Wisconsin!
    Yeah, lemon huh? And how's it running now that you took out those two cracked plugs you installed? And I still don't believe your claim on shoforum that you have a 190* tstat in it.
  9. #9 Re: Dealership sold me a modded Lemon >:(
    People mod those? Hmm didn't know that
    04 Comp G.
  10. #10 Re: Dealership sold me a modded Lemon >:(
    Buffalo
    More info?
  11. #11 Re: Dealership sold me a modded Lemon >:(
    Feb 2013
    37.295091, -121.930053
    its a ford
    Fix
    Or
    Repair
    Daily
    enough said lol but really ford has gotten better at building thing that can last
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  12. #12 Re: Dealership sold me a modded Lemon >:(
    Nov 2013
    Wisconsin!
    They make massive gains with simple bolt ons. Less money, and more hp per mod then a gp actually. And a trans that isn't glass.
  13. #13 Re: Dealership sold me a modded Lemon >:(
    NYC
    It's amazing what more than a decade of newer technology can accomplish! Who would have thought!!!
  14. #14 Re: Dealership sold me a modded Lemon >:(
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by koRnhead View Post
    Want a list of the faults with the car?
    1. The trans slams and I mean SLAMS into 4th, downshifting into 3rd takes at LEAST 3 seconds every time.
    2. if the trans gets pushed even slightly hard, it starts lagging and slamming every gear.
    3. The car hesitates off the line, it has a about a second where it has no idea whats going on.
    4. The radar cruise control sensor is broken meaning I have no cruise control.
    5. The oil pressure light has been on twice, yes I have checked the oil level its fine.
    6. The spark plugs made no difference other than fixing the misfire.
    7. The car will drive arrow straight one moment then start pulling to the left. Same road Different days it can go straight, or the wheel will turn 20* to the left as soon as my hand comes off . Yes, ive had it aligned.
    8. The car has a bad axle or something, because at about 60 it shakes anytime throttle is applied. and im not talking about a mild little vibration, I mean it shakes, and bucks.
    9. The Dealer is replacing a wheel bearing on the car as part of the we owe (not my problem, but still another fault)
    9 problems discovered in less than 2 weeks. If that's not a lemon, then I don't know what to call it, but nothing good.
    Even with the warranty im looking at probably over a thousand dollars in deductibles and diagnostic fees.
    As for the thermostat, ill say again what I said on SHO forum: " First I will say the car has a 190* Tstat, Temp hovered around there the whole time." I was reading 87*C to 89* C which is 188-192F.
    To me that's closer to the temps of a 190 than 180 but maybe that's just how the 180s work, or maybe mine is faulty.
    I wouldn't have bought it had I know it was tuned, From personal experience people who mod their cars, drive them to make use of those mods. Its clear that the last driver either ran the crap out of this car or didn't take care of it. I still have no idea what tune its running, and Im a fan of spending money to find out.
  15. #15 Re: Dealership sold me a modded Lemon >:(
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by Bronco Boy View Post
    I signed the final set of paper work on 6/23 so less than 2 weeks. My bank hasn't even posted the loan to my account yet.
  16. #16 Re: Dealership sold me a modded Lemon >:(
    Jul 2010
    Coquitlam,BC,Canada
    Wow. Less than I had guessed. I can't believe there is no recourse in a case like this. I'd be in the dealers face making their lives miserable.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  17. #17 Re: Dealership sold me a modded Lemon >:(
    Buffalo
    Is it an actual ford dealership or just a corner lot dealer ?
  18. #18 Re: Dealership sold me a modded Lemon >:(
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by CrazyGuy03 View Post
    Ford dealer
  19. #19 Re: Dealership sold me a modded Lemon >:(
    Sep 2014
    Richmond Virginia
    Saturday they are replacing a wheel bearing. It was supposed to be in the we owe, but ... conviently they cant find it. So im sort of dependent on their good will until then. In the mean time, I am trying to gather as much information as possible. Im trying to get the Extended warranty people to tell me if the Tune voids the warranty without telling them what car was tuned . If the warranty is Voided then I have some serious ammo to use. I am also considering talking to my credit union and getting them involved. If im going to war with these people I want to have my facts straight.
  20. #20 Re: Dealership sold me a modded Lemon >:(
    Wichita
    Some stuff on Lemon Laws in your state. Maybe it'll help maybe not.
    http://www.dmv.org/va-virginia/autom.../lemon-law.php
  1. ok, now its ABS trouble......... can you say LEMON!?
    By sasquatch in forum General Tech Discussion
    Last Post: 12-04-2010, 12:59 PM
  2. my 95 is a lemon
    By grandprix95 in forum The Rant Forum
    Last Post: 01-17-2009, 09:26 PM
  3. My 08 is turning out to be a LEMON
    By willie769 in forum The Rant Forum
    Last Post: 01-07-2009, 07:54 AM
