Thread: Sticky situation
Results 1 to 10 of 10
  1. #1 Sticky situation
    Apr 2016
    Battle Creek MI
    Hi members this is my first post. I recently purchased a 2001 Grand Prix. It requires an ink pen shoved into a hole under the steering column to remove the key. What part do I need to repair my ignition and how difficult is the process?
  2. #2 Re: Sticky situation
    you can open the column and remove the part your pushing up, zip tie it, or replace it, or cut a straw like a fat burger king one so that when it pushes the button up with the cap back on under the column.
  3. #3 Re: Sticky situation
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
  4. #4 Re: Sticky situation
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I did what Scott said, I have a straw pushing it up the whole time. It occasionally falls out going over bad bumps in the road, but that's after a month or two. If you want the permanent fix, you need to rip apart your center console and fix a bad wire.
  5. #5 Re: Sticky situation
    Apr 2016
    Battle Creek MI
    Thanks guys I'll try this out & let you know how it goes.
  6. #6 Re: Sticky situation
    Jan 2014
    AR
    Mine has had a folded up business card in it since before I got it 2 1/2 years ago. Hasn't fallen out, and my trim panel is even broken and hanging down.
  7. #7 Re: Sticky situation
    Apr 2016
    Battle Creek MI
    I took a dense piece of foam like what they use for yoga mats, cut a 2 inch square and shoved it up under the button the pressure from the button made an imprint which should permanently secure it. Thanks again for the suggestions.
  8. #8 Re: Sticky situation
    A straw? Some foam?
    God the laziness lol. Jesus Christ, people.
    Just remove the damn plastic cover and rip out the white lock solenoid. It's that simple.
  9. #9 Re: Sticky situation
    Donating Users
    phila pa
    look under shifter.take cover off broken wire on harness in front of shifter under cover.
    http://eaccess.smpcorp.com/eCatalogs...14&Part=PT5942
    http://eaccess.smpcorp.com/eCatalogs...PT5942&SType=0
  10. #10 Re: Sticky situation
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    Quote Originally Posted by blueguy View Post
    A straw? Some foam?
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  1. Car vs car situation
    By Jevik in forum General Grand Prix Discussion
    Last Post: 06-28-2013, 12:29 PM
  2. ABS Situation
    By Egleone6 in forum General Grand Prix Discussion
    Last Post: 03-26-2012, 02:35 AM
  3. umm help with headlight situation
    By caseyv in forum Visual/Body Modifications
    Last Post: 12-25-2011, 12:05 PM
  4. A very peculiar situation...
    By jerZcavy4120 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2011, 08:55 PM
  5. KR Situation
    By mechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2011, 12:42 PM
