Thread: Speedometer help
Results 1 to 3 of 3
  1. #1 Speedometer help
    SE Level Member joemost's Avatar
    Jan 2014
    I have an old mini van... which I use for a work van.. it is a 1994 pontiac transport. Everything works great on it except for the speedometer.
    The speedometer goes all crazy when I am driving it. It isnt just blank....but itll say I am going 80 mph when I am going 30. I usually just used my gps to track speed...because it actually works really well. But I can't currently get it to pass inspection because no working speedometer.
    I tried replacing the Vechile speed sensor... did not have any difference on the speedometer. Any thoughts or ideas would be amazingly helpful.
    Sent from my SCH-R970 using Tapatalk
    Using Tapatalk
  2. #2 Re: Speedometer help
    Check the wiring to the gauge.
  3. #3 Re: Speedometer help
    Aug 2014
    houston
    just had a similar problem in my 2002 pontiac grand prix. get someone to check the cluster either it can be fixed my moving part of the cluster or you have to get a new one. the cluster is the part that is under the gauges it looks like the inside of a computer with the chips and all. hope i helped even though your post was from a while back
  1. HUD Speedometer
    By jacobmh27 in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2012, 11:52 AM
  2. Speedometer help
    By ElAlacran2010 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2011, 10:55 PM
  3. 99 GTP speedometer
    By cfallsguy in forum Audio, Security & Visual Electronics
    Last Post: 07-31-2010, 10:57 PM
  4. Speedometer ??
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 04-17-2009, 10:53 PM
  5. speedometer
    By digilue in forum General Tech Discussion
    Last Post: 12-28-2008, 07:10 AM
