Thread: Glow Shift Gauges Discount
Results 1 to 20 of 27
  1. #1 Glow Shift Gauges Discount
    These gauge are great and the price is not bad either on most of them.
    Discount code is SPRING2011, type that in at checkout to save 15% off your order.
  2. #2 Re: Glow Shift Gauges Discount
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Is that active right now? I know i got one like this recently but it ended like the 15th
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  3. #3 Re: Glow Shift Gauges Discount
    yes, i got the email this morning.
    OFFER EXPIRES ON MARCH 31st.
  4. #4 Re: Glow Shift Gauges Discount
    Jul 2010
    Michigan
    I was just going to reply I just checked my e-mail and this is true I got the e-mail as well. Already have one gauge will probably get a WB 02 from them for new and only like 160 or so after discount hell ya. Not to mention you can get underbody leds from them with this code to at their other site LEDGLOW. A friend has used them also and they are good
    2005 GTP Grey
  5. #5 Re: Glow Shift Gauges Discount
    GT Level Member 2000GrandPrixGT2000's Avatar
    Trevose, PA
    Under body LEDs do not belong on a grand prix in any situation
    2000 Grand Prix GT- DIY Spectre HAI, KYB GR-2 Struts, GMPP Front and Rear Sway Bars, GMPP Front and Rear Strut Tower Braces w/ Don Rome Brackets
    Soon to be Installed: Poly Bushings + Poly End Links- Front and Rear GMPP Sway Bars
  6. #6 Re: Glow Shift Gauges Discount
    Jul 2010
    Michigan
    I was putting it out there and that is an opinion
    2005 GTP Grey
  7. #7 Re: Glow Shift Gauges Discount
    Nov 2010
    Marine City MI
    I have the oil pressure and trans temp they work great.
    99 GTP, ZZP MPS 2.9 pulley, GenIII supercharger ported & polished, machined intake W/ stage 2 intercooler, XP Cam,ZZP fuel rails, 42.5 injectors, Wizard CAI, custom headers, 3 inch downpipe, into dynomax muffler,180 stat, Northstar TB, 85mm MAF, ZZP trans, 3.29 gears, input shaft and torque converter, stock heads W/Ls6 springs.
  8. #8 Re: Glow Shift Gauges Discount
    Jul 2008
    Tampa, FL
    is it just me or do those gauges look cheap as all getout? how are they in person?
  9. #9 Re: Glow Shift Gauges Discount
  10. #10 Re: Glow Shift Gauges Discount
    Jul 2010
    Michigan
    I ahve a boost one that Im putting in now. Once I have garage time itll be in
    2005 GTP Grey
  11. #11 Re: Glow Shift Gauges Discount
    Pennsylvania
    Free shipping and a $15 discount. THANKS!
    That thar's beer money!
  12. #12 Re: Glow Shift Gauges Discount
    GT Level Member starscream5000's Avatar
    Kentucky
    I've got their boost gauge (mechanical)
    Oil temps (electronic)
    Oil pressure (electronic)
    and oil sandwhich plate.
    Very nice gauges, but DO NOT BUY THE TINTED ONES! You will not be able to see **** from them in the daytime on the red color setting or blues.
    At night time the gauges look like they are factory for the car when they're red. I'll be buying about 4 more for my other car when I drop the new motor in it. Going with the clear lense next time.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  13. #13 Re: Glow Shift Gauges Discount
    GT Level Member Whitehispanic's Avatar
    Westborough
    What the website ???
    *sig too tall*
  14. #14 Re: Glow Shift Gauges Discount
    Pennsylvania
    Quote Originally Posted by starscream5000 View Post
    Balls.
  15. #15 Re: Glow Shift Gauges Discount
    SE Level Member MTchevy1's Avatar
    Illinois
    I've got them in my s10, they look awesome but I did get one bad one. On my trans temp gauge, the needle contacts the housing at one spot, enough to stop it from going up any further. They were really cool on the phone though and offered to replace it, but I'm going to pop the lens off and just sand a little off the end of the needle. Not a big deal, just a heads up that sometimes stuff slips past their QC.
  16. #16 Re: Glow Shift Gauges Discount
    Quote Originally Posted by Whitehispanic View Post
    google helps brah
    GlowShift Performance Gauges & Pods ? Automotive Boost Gauges, Pyrometer
  17. #17 Re: Glow Shift Gauges Discount
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    i had the tinted nb 02 guage. worked like it should and the feature to change the color is pretty cool.
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  18. #18 Re: Glow Shift Gauges Discount
    GTX Level Member real diehl's Avatar
    Salina, KS
    Product Information
    Product Name Item Number Quantity Item Price Total Price
    Black 7 Color 30 PSI Boost / Vacuum Gauge
    GS-C701 1 $39.99 $39.99
    Black 7 Color Oil Pressure Gauge
    GS-C704 1 $54.99 $54.99
    Subtotal: $94.98
    Discounts: -$14.25
    Shipping & Handling: $0.00
    Tax: $0.00
    Order Total: $80.73
    **** yeahhhh
    signature removed for inappropriate content.
    -bio
  19. #19 Re: Glow Shift Gauges Discount
    Houston
    Quote Originally Posted by vailskier3 View Post
    I think they look good. Got a mechanical boost 7 color white face and oil pressure 7 color white face. You can make them match with any color scheme.
  20. #20 Re: Glow Shift Gauges Discount
    GT Level Member 99GTRED's Avatar
    Oct 2011
    Grand Rapids, Michigan
    where did you got those gauges? not the ones in the pods like the speedometer and gas and temp etc?
  1. green glow gauges
    By Poil336 in forum Audio, Security & Visual Electronics
    Last Post: 09-20-2011, 09:53 PM
  2. Glow gauges?
    By apierce1289 in forum Audio, Security & Visual Electronics
    Last Post: 03-25-2011, 09:21 AM
  3. Blinkers and glow gauges not working ?
    By JimJimSpa in forum General Tech Discussion
    Last Post: 05-24-2010, 03:00 PM
  4. glow gauges
    By windycitygtp in forum Visual/Body Modifications
    Last Post: 03-03-2010, 10:23 PM
  5. glow shift gauge
    By nemesis in forum Visual/Body Modifications
    Last Post: 03-14-2008, 01:03 AM
