Thread: Common part numbers: Pulleys, Goops and Gaskets
Results 1 to 10 of 10
  1. #1 Common part numbers: Pulleys, Goops and Gaskets
    Please add on if you have more stuff. It's always good to give folks more info.
    Pullies
    Series I
    Tried to find info on Series I and only came up with one pulley used twice.
    Part#....OD......ID.........Info
    89007...76mm...17mm...23mm flat pulley
    Series II
    L36
    Pos...Part#....OD.......ID.......Wide.....Info
    3......89007...76mm...17mm...31mm...flat
    L67
    9......89006...90mm...17mm...30mm...flat
    8......89051...76mm...17mm...23mm...6 rib with flange
    L67 with 8 Rib SC Pullies
    8......89053...76mm...17mm...NA........8 Grooves with flange (3")
    8......89057...90mm...17mm...NA........8 Grooves with flangle (Optional 3.5")
    3 SC..89016...74mm...17mm...37mm....flat (SC tensioner pulley)
    9......89048...90mm...17mm...37mm....flat (Optional 3.5" for pos 3 if SC'd)
    3......89007...76mm...17mm...31mm...flat (6 rib accessory belt tensioner pulley)
    ** All part numbers are from the Dayco.com website.
    Gaskets/Parts
    Series 2
    Part # ............Name.................................. ...............Rockauto
    Fel Pro
    MS98014T........Aluminum LIM gaskets..............................$51.79
    70644..............Oil Filter Adapter Gasket............................$1.09
    ES70599...........Fuel Injector O-rings (need 3)....................$1.91
    VS50465R.........Valve Covers (L67) w/grommets................$40.79
    VS50080R.........Valve Covers (L36) w/o grommets...............$9.38
    ES72833...........Valve Cover grommets..............................$7.26
    MS95744...........Plenum (SC to LIM) gasket w/rings (L67).....$8.43
    MS95812...........Plenum (UIM to LIM) gasket (L36).............$32.99
    61024..............Throttle Body gasket (L67)........................$3.52
    61093..............Throttle Body gasket (L36)........................$3.72
    35595..............Thermostat Housing gasket........................$1.00
    35666..............Thermostat Seal (rubber)...........................$1.87
    CS9917.............Lower Conv gasket set (96-99)................$30.79
    Dorman
    47065..............Coolant elbow.........................................$4.0 0
    47065HP........Aluminum Coolant Elbow
    47037...............Map/PCV Cap kit..................................$~10.00
    Napa
    660-1736..........Coolant elbow.........................................$?
    GM Dealer
    89017816 ..........L36 Lower intake gaskets........................ ~$50
    89017825 ..........L67 Lower intake gaskets........................ ~$50
    24505049..........Rear Int Coolant Cover....................~$8 (the lim coolant cover under TB)
    89017274..........L36 map/cap kit................................~$20
    12346004..........GM Pipe Sealant with PTFE...................... ~$10
    12345982..........GM S/C Oil (M62 1, M90 need 2).................~$10
    12584411..........Gen V M90 Aluminum gasket......................??
    1052943...........Gasket Maker.(Charger snout to body seal)......??
    16194007..........NA (L36/L26) MAP sensor accoridan seal
    Parts Store
    Permatex Ultra Copper RTV - works for every fluid in our cars except supercharger
    Permatex High Temp RTV Silicone Gasket Maker 26B - Used for sealing paper gasket on intercooler.
    Shorter Dog Bones: Anchor 2899 (Montana)
    Oversized Radiator: Spectra CU1518 (95 Lumina 3.4L, need 95 GP lower hose)
    Adding stuff
  2. #2 Re: Common part numbers: Pulleys, Goops and Gaskets
    ill move this, i just havent figured out where would be a good place yet..
  3. #3 Re: Common part numbers: Pulleys, Goops and Gaskets
    Take your time...I'm opening the flood gates on you.
  4. #4 Re: Common part numbers: Pulleys, Goops and Gaskets
    GT Level Member neel2008's Avatar
    Huntington, IN
    I'll add some Autozone part numbers I suppose cause I'm bored.....
    Pullies
    Series II
    L67
    Pos...Part#.........OD.............ID............W ide.........Info
    7......34195.......................................................A/C bypass pulley
    8......231086.......76.............17mm........12mm.......groov ed pulley
    3......231107.......76.............17mm........12m m.......smooth w/ no flange
    9......231081.......90.............17mm.......12mm......3.5" smooth
    4......300-130......5-25/32 in..................1 5/32 in...usually special order
    * ID and Wide are bearing sizes according to Autozone computer.....
    Gaskets
    Autozone carries felpro gaskets so the felpro numbers come up in the computers......
    Other Crap
    Item name.........Part#......Warrenty...Info
    motor mount......15309......LLT..........Torque strut (dogbone) to radiator support *hint: search the forum on how to "flip" these when installing them.
    motor mount......2866........LLT..........Torque strut mount AKA "dogbone" (standard length)
    motor mount......2899........LLT..........Torque strut mount AKA "dogbone" (99 pontiac montana 3.4, said to be shorter)
    motor mount......2796........LLT..........Other motor mount
    front hub...........513121....1YR..........Timken front bearing/hub assembly
    front hub...........DL513121.1YR..........Duralast front bearing/hub assembly
    rear hub............512237....1YR..........Timken rear bearing/hub assembly
    rear hub............DL512150.1YR..........Duralast rear bearing/hub assembly
    cv shaft............9471N......LLT..........New Duralast Gold drivers side (usually special order)(both GTP and Non-GTP)
    cv shaft............n/a..........n/a..........New Duralast Gold passenger side (NOT AVAILABLE)
    9471........LLT..........Reman Duralast drivers side(both GTP and Non-GTP)
    cv shaft............9472........LLT..........Reman Duralast passenger side(GTP model with 4t65-e HD tranny)
    9468........LLT..........Reman Duralast passender side(NON-GTP models with standard 4t65e tranny)
    fuel filter...........
    FF4508...................Located on sales floor at most Autozones, you can go get this one yourself!
    oil filter.............3387.......................Stan dard filter in STP and Fram
    oil filter.............3331.......................Standard filter in Bosch
    M1-101...................Standard filter in Mobil
    HP-1001..................Standard filter in K&N
    oil filter.............PF47.......................Standard filter in AC Delco
    oil filter.............3980.......................Extr a long filter in STP and Fram
    oil filter.............3430.......................Extr a long filter in Bosch
    oil filter.............M1-201....................Extra long filter in Mobil
    oil filter.............HP-2001...................Extra long filter in K&N
    oil filter.............PF-52......................Extra long filter in AC Delco
    *(can ask for oil filter for a 97 s10 2wd 4.3L if you have problems locating the longer filter)(I use the longer filter on my 97 GTP with no problems, usually cost the same for more filtering material so why not?)
    air filter.............8136......................Blue 3inch Spectre open cone filter
    air filter.............8132......................Red 3inch Spectre open cone filter
    air filter.............8138......................Chrom e 3inch Spectre open cone filter
    air filter.............888038...................HUGE 3.5/4 inch washable/reusable Spectre filter (like 10 inches tall and 6 inches around)
    *If mounting right to TB, you will need to make a hole in the rubber of the filter for the IAT sensor......
    Oversized Radiator...........................Same numbers as bill's post
    Lower Rad. Hose..D72038..................95 GP 3.1L lower hose
    Lower Rad. Hose..B71778..................95 GP 3.4L lower hose(think this one is right, maybe Bill can chime in and confirm he meant 95 GP 3.4L lower hose)
    LINK TO ALL THE LOAN-A-TOOLS>>>>>http://www.autozone.com/autozone/acc...d?target=shelf (hope its ok to post the link?)
    (yes the W-Body specific strut spring compressor tool is in there under part# 27034)
    (the 27032 flange puller attachment and 27033 slide hammer can help get those stubborn bearing/hub assemblies out, or just hit them with a hammer. lol)
    For some reason, we don't have the fuel line disconnect tool (for the lines that go over the supercharger) in loan a tool but the part number you should need is 25043, which you have to buy.
    *LLT=Limited Lifetime Warranty, 1YR=1 Year Warranty
    *No Prices because prices will vary between Autozone stores.....
    If you guys find this useless, then ill leave it at this, if you guys think its helpful, let me know and Ill post more.....also if you see any errors or part numbers you would like to see, please let me know!
    I am NOT doing this to try and promote Autozone (yes i work there). I am simply trying to use my position as an employee to provide info for fellow GP'ers....
    edit:not sure why there are extra spaces here and there, i tried to fix them but it wouldn't let me.....
    97gtp
  5. #5 Re: Common part numbers: Pulleys, Goops and Gaskets
    Huntington, IN
    Autozone part no. 17014 - Bosch Wideband O2 sensor.
    97gtp
  6. #6 Re: Common part numbers: Pulleys, Goops and Gaskets
    Aug 2011
    New York
    Thank you, very practical。
  7. #7 Re: Common part numbers: Pulleys, Goops and Gaskets
    Waukesha, WI
    thanks guys
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  8. #8 Re: Common part numbers: Pulleys, Goops and Gaskets
    Coolant Water By-Pass Gasket VICTOR REINZ Part # C31274
  9. #9 Re: Common part numbers: Pulleys, Goops and Gaskets
    Mar 2015
    USA
    Dayco 89051 - Ribbed idler pulley/supercharger - Doesn't properly fit without modification
    This pulley is metal, and the OEM bolt/washer rubs the front and prevents it from turning.
    Going to try Gates 38009 next. It's a plastic unit that looks like the stock one.
  10. #10 Re: Common part numbers: Pulleys, Goops and Gaskets
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
    89057 Dayco width is 37.65mm
  1. Oil in my coolant? LIM? Need part numbers and what is best to get....
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2011, 01:13 AM
  2. Brake Part Numbers
    By Suaveat69 in forum Brakes/Suspension/Chassis
    Last Post: 07-12-2010, 10:02 PM
  3. Pulleys = what boost numbers?
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2009, 09:28 PM
  4. Fitting Part Numbers?
    By Scimmia in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2009, 09:47 AM
  5. Part numbers
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:50 PM
