Thread: CAI
Results 1 to 13 of 13
  1. #1 CAI
    SE Level Member GTP Ryan's Avatar
    Mass
    im thinking about purchasing a k&n cai
    K&N FIPK Air Intake Kit - 04-06 Grand Prix 57-3049 - PFYC.com
    does anyone have any experience with this particular product, was their a noticeable gain in performance/sound/fuel economy?
    also is this the only one applicable to an 04 gtp because ive looked around and can only find that one, i would like to get the 63 series but all the auto stores ive gone to say the 57 series one is the only one that shows up for that car
  2. #2 Re: CAI
    Charles City, IA
    Put a filter on the end of your maf and be done with it. You can run a little piping to get it close to your fender. I have amsoil filters that I sell below retail.
    SMGPFC Two Nipple General
  3. #3 Re: CAI
    Charles City, IA
    There is no point to spend $350 on an intake.
  4. #4 Re: CAI
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    agreed.. mines right on the intake now
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  5. #5 Re: CAI
    Mass
    thanks guys, turns out i probably wont be getting a cai for awhile, may need to replace the rack and pinion on my car, lucky me lol
  6. #6 Re: CAI
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    mine is 4 inch pvc pipe with a big@$$ filter on it. cheap build.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  7. #7 Re: CAI
    Charles City, IA
    Quote Originally Posted by a98gtp4u View Post
    I bet mines bigger.
  8. #8 Re: CAI
    GEORGIA
    4 inch filter 9 inches long.
  9. #9 Re: CAI
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    what did you do with the old one?
  10. #10 Re: CAI
    Charles City, IA
    4"inlet 6.6" base 9.5" long 5.25" Top
  11. #11 Re: CAI
    SE Level Member ne04gtp's Avatar
    Omaha,NE
    I have the K&N for the 04 GTP. All in all it is just fine....Had to sand the edges where the filter connects to the pipe....it was slipping off a bit so i gave it some texture. Hp gains are decent and it sounds cool I suppose.
  12. #12 Re: CAI
    GT Level Member kjclawson's Avatar
    Fort Myers, Florida
    350 is a lot for a CAI but i have a K&N and they have a really good sound
  13. #13 Re: CAI
    Quote Originally Posted by kjclawson View Post
    you know an open cone, which would be the cost of a cone filter, will sound better?
cai
