Does anyone no if u can buy an intermediate steering shaft cheaper then 130 bucks from the dealer new. Just thought I'd try get one cheaper but I want a new one not used thanks for any help.
Have you checked like an OReilly , Autozone, or Napa?
Wonder how hard one is to replace?
rockauto.com its like $60 bucks.
scotty its not that hard gezz its just a bit small in some places lol. its not that hard once you get your column out. just 1 big hammer to bang one end on the column then fit it on the boot then bolt it in its really took me 2 hrs to do. and it took that long because I was doing my laundry lol.
the one i put one fought me tooth and nail on the column side, the rack side went right on. cut my finger on something real sharp on the column side too. whole job just pissed me off from the get go. i spent a easy 2 hours on it.
Not a bad job changed mine when i put the regal rack in my monte
Just finished mine 2 minutes ago. FMFLFUMFB
Yea time for a cold beer. Job was easy overall.
Jacked car up
Took off wheel.
Made sure wheel was straight
Lifted up boot inside wheel well
Took out bolt (11mm)
Stretched under the dash
Turned wheel a bit to get nut off shaft
Took out screw
Made sure wheel stayed where it started
Greesed it. ( a little bit of a ***** for my without the rubber, i used my thumb, very messy)
Stuck shaft back in (alignment pin makes it easy)
Screwed in top
Then the bottom............................................ .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ......................MOTHER****ING*****WHORE**** SIP SIP SIP **** YOU HOE.......SHOT.......**** *****............................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ......FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF.. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ............................Turn wheel a tiny bit. Plop O.o WOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Sip sip sip/shot....
Tighten bolt.....
Put wheel back on
Now im here...lol
