Thread: High gear trans problem. 95 GTP
Results 1 to 8 of 8
  1. #1 High gear trans problem. 95 GTP
    Jun 2010
    long island ny
    I have a 95 GTP with the DOHC motor. The problem first happened about 2 months ago, the car wouldn´t go into high gear and on the parkway it was about 3100 RPMS at 70. But it started to work again and I forgot about it. Until it happened this morning on the way home from work. The trans was working fine and then I noticed the rpms were 3100. I tried shifting into the lower gear and then shifting up again but that didn´t help. The trans shifts fine but just won´t go into high gear. Checked the trans fluid and the level was fine. Trans shifts nice into the other gears. The car has 70,000 miles on it and the trans was rebuilt just before I bought it. Any ideas. Could it be the linkage is out of adjustment. Sometimes I have a problem with that.
  2. #2 Re: High gear trans problem. 95 GTP
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    prob the 4th gear hub finaly lost all its teeth
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: High gear trans problem. 95 GTP
    Jun 2010
    long island ny
    Quote Originally Posted by 00grandprixgtp View Post
    The trans has about 3000 miles on it.
    Took it on the parkway just now and it worked fine, must be something electrical. What should I look for.
  4. #4 Re: High gear trans problem. 95 GTP
    Johnstown, NY
    I would check the condition of the vacuum line on the front of the tranny.
    98 Red Coupe Grand Prix GTP : 180* T-stat, U-Bend delete, NGK TR55's, SLP Catback
    My Ride: http://www.grandprixforums.net/jevik...upe-73301.html
    A must read for modding: http://www.grandprixforums.net/safel...0-a-67580.html
  5. #5 Re: High gear trans problem. 95 GTP
    Jun 2010
    long island ny
    Quote Originally Posted by Jevik View Post
    Does that control all shifting or just the shift into 4th. All the others shift normally.
  6. #6 Re: High gear trans problem. 95 GTP
    There are two soleniods that control shifting. For the first three gears to work properly, they both have to be working properly. the only thing that might hold fourth up from working is likely the shift cable position.
  7. #7 Re: High gear trans problem. 95 GTP
    Jun 2010
    long island ny
    I have been having some trouble getting the key out, I would have to play with the shifter and it would come out. Also I notice the shifter may be in neutral and be in 4th gear. Maybe when the previous owner had the tranny done they didn´t adjust the linkage. What should I be checking for and how is it adjusted.
    I know it has to be something like that because the fluid is not burnt, the car shifts great and yesterday I took it on the parkway and had no problems.
  8. #8 Re: High gear trans problem. 95 GTP
    I don't have an adjustmetn procedure for you. Search here, google it.. I'm sure there's one out there.
  1. trans comes out gear on hard stop
    By richduty455 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-19-2013, 12:28 PM
  2. 96 Grand Prix SE taking off in high gear when hot
    By alacran in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 09-03-2012, 08:31 AM
  3. High idle in every gear
    By shart in forum General Tech Discussion
    Last Post: 10-20-2011, 07:46 AM
  4. no 1st gear, trans shop says it's pcm
    By jdmgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-12-2010, 05:22 PM
  5. Trans hangs in 2nd gear
    By singularity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-29-2009, 11:42 AM
