Thread: Higher Drive Ratio... Stock Tune
Results 1 to 3 of 3
  1. #1 Higher Drive Ratio... Stock Tune
    Apr 2013
    NM
    I have a 4T60E in my 98 Grand Am with the 2.4L Twincam that has the 3.05 differential assembly and wanting to swap in the 3.29 diff. Stock the trans already has the 33/37 chain sprocket which is a 3.42 ratio with the 3.05 diff. So im wondering if I will have any problems adding the 3.29 diff to make a 3.66 overall ratio? will it run in limp mode, not go over 25 mph, get hot, and shift hard. Also I have a plus zero tire going from stock 195/70R14 to 205/70R14. I do have a BandM line pressure adjuster off the vacuum modulator to help with the shift firmness. Can the swap be done and the computer like it?
  2. #2 Re: Higher Drive Ratio... Stock Tune
    Computer will likely throw codes for a trans related issue because of the gear ratio change.
  3. #3 Re: Higher Drive Ratio... Stock Tune
    Jul 2012
    Chicago
    Would need HPT or a tune to retune the car to work with the gear ratio change.
    -Carl
  1. New ZZP rear springs ride height question (higher than stock)
    By hifi dream in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:49 AM
  2. What ratio rocker arms can i run with stock springs?
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-27-2011, 11:06 AM
  3. Pulley Drop Vs Higher Timing (Custom Tune)
    By TheAce144 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2011, 09:25 PM
  4. What will my final drive ratio be?
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-02-2010, 01:09 AM
  5. Final drive ratio question
    By 07CrimsonGT in forum General Tech Discussion
    Last Post: 08-11-2009, 05:58 PM
