Thread: Transmission problems on a 97 chevy lumina
Results 1 to 4 of 4
  1. #1 Transmission problems on a 97 chevy lumina
    SE Level Member tgarison's Avatar
    Abilene, Tx
    Hey all,
    I am having a problem with my parents 97 chevy lumina I have done my research so I know it has a 4L60-E trans. the problem is it wont shift into 1st or reverse most of the time, once it does it drives just fine I am thinking the shift solenoid is bad my questions are that, is the shift solenoid on the inside of the trans or can i access it from the outside? If its on the inside will i have to drop the valve body to get to it? They seem to think all that it needs is a fluid and filter change and to get a flush done but I don't think that's the problem. What do all of you think?
    Thanks in advance,
    Tgarison
    If you want to find out more about me or my GPGT click the link below it takes you to my youtube channel.
    http://www.youtube.com/user/grandprixgt1999
  2. #2 Re: Transmission problems on a 97 chevy lumina
    Dec 2012
    troll land
    fluid and filter (owner 97 monte)
  3. #3 Re: Transmission problems on a 97 chevy lumina
    Abilene, Tx
    I already tried dropping the pan and replacing the fluid and filter and saw no difference
  4. #4 Re: Transmission problems on a 97 chevy lumina
    4t60
  1. 1992 chevy lumina minivan ball joint?
    By Points70 in forum General Tech Discussion
    Last Post: 09-29-2011, 09:30 PM
  2. 3.1 chevy lumina code p0401 help
    By Whitehispanic in forum Off Topic Discussion
    Last Post: 07-06-2010, 10:01 PM
