Thread: Car rolls in park
Results 1 to 9 of 9
  1. #1 Car rolls in park
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    I just finished my engine swap, however, I havent bolted the flexplate to the torque converter yet. Anywho, when I went to push the car back to its parking space I didnt even have to put the car in neutral, it just rolled! Is this something I should be concerned about before I finish the install? Thanks.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  2. #2 Re: Car rolls in park
    Barksdale AFB, LA
    Sure the parking cable is adjusted properly so that when the shifter is in park, the trans is in park?
    2009 Subaru Impreza WRX STI
  3. #3 Re: Car rolls in park
    Feb 2008
    Houston
    I never touched anything with the tranny. just unbolted it from the old engine...
  4. #4 Re: Car rolls in park
    Barksdale AFB, LA
    Quote Originally Posted by t24moore View Post
    There's a cable that runs from the shifter in the cabin to the lever on the tranny. It has a large adjuster along it somewhere for you to adjust the cable. Disconnect the cable from the tranny and push its lever all the way to the firewall (park). Then push the shifter in the cab all the way to park. If the cable no longer lines up with the lever, it should be adjusted.
    This may no be the official method, and I'm too tired to look it up, but the backwater method should work just fine.
  5. #5 Re: Car rolls in park
    Feb 2008
    Houston
    Thanks sabre, I will give it a shot. I just don't understand how that could have happened when I never messed with anything on the tranny....it stayed in the car the whole time.
  6. #6 Re: Car rolls in park
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    If your cable checks out OK and you are definately in Park range on the trans then you should check the axles to make 100% sure they are both in all the way and somehow one of them didnt partially come out which will cause the trans to not have park as the unconnected side of the diff will freewheel whether in park or not.
  7. #7 Re: Car rolls in park
    Feb 2008
    Houston
    Thanks everyone. I did have to use the shift lock release to put the car in neutral to move the car. Could this have an effect also? Thanks again.
  8. #8 Re: Car rolls in park
    Fort Wayne, IN
    ????? I thought it rolled in park, why did you need to put it in nuetral? Anyways the above aside, IF the linkage or range switch position at the transmission is not correct or misadjusted now then you will have to push the shift interlock button to take it out of park.
  9. #9 Re: Car rolls in park
    Feb 2008
    Houston
    Sorry trannyman, I had to put it in neutral because I needed to move the car back for more room to use the engine hoist. This is when I used the shift lock release because it wouldn't come out of park with all the electronics. After I put the engine in I was finished for the night and needed to push it back in the parking space. This is when I noticed that it rolled in park. This was my first engine swap, I was hoping I didn't screw anything up with the tranny during the process of taking the engine out. Sorry for being schizophrenic about this.
  1. Replies: 7
    Last Post: 07-07-2010, 08:58 AM
  2. 01 GTP. Car shakes when in Neutral and Park.
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 03:00 AM
  3. Pontiacs in the Park-VA
    By mlambert in forum Shows and Events
    Last Post: 06-03-2008, 09:06 PM
  4. Park Ave owners welcome?
    By gonneville in forum Introductions/Noob Questions
    Last Post: 01-11-2008, 10:13 AM
