Starting out the tranny won't shift out of 1st gear till I let off the throttle or till it is almost on rev limiter. I replaced the vacuum mod no change. Any help would be appreciated.
Thanks
DaveB
Thanks
DaveB
If you replaced the modulator, then you likely ensured the vacuum line to it was good as well?
Yes I checked the vacuum lines they are ok. The problem is intermittent so it is possibly a valve sticking. I'm going to try some Lucas and see if that helps.
Thanks
Dave
