Thread: 2004 Grand Prix Trans filter/fluid change. HELP!!!
Results 1 to 2 of 2
  1. #1 2004 Grand Prix Trans filter/fluid change. HELP!!!
    SE Level Member frtaylor9's Avatar
    United States
    Just bought my transmission filter and some Supertech ATF (say's it can be used in GM models pre-2006 transmissions on the bottle). (Suitable for use in all General Motors transmissions where Dexron-II & III, Mercon fluids are specified.
    I'm just curious as to what kind of job it is to change the tranny filter. Is it something I can do myself or should I pay someone to change it?
    & what is the right kind of fluid to use in it. I don't want to ruin the trans due to wrong selection of fluid.
    All & any tips and hints would be helpful
    Thanks
    2004 Grand Am GT1
  2. #2 Re: 2004 Grand Prix Trans filter/fluid change. HELP!!!
    Portland Oregon
    Your trans takes dexron 3 so you're ok. Filter is easy. Once you have the pan down you just pry it out of the inlet hole. It's a snug fit
  1. Trans Fluid/filter
    By Pshnmeawy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-20-2011, 08:43 AM
  2. P0742 after fluid and filter change.
    By aeidian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-10-2010, 03:54 PM
  3. Hardshifting after new fluid and filter change.
    By Pontiacman76 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2010, 05:47 PM
  4. Tranny fluid and filter change
    By chevyy1212 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2010, 03:49 PM
  5. (Solved) Trannyman Help! im in the middle of trans filter change.
    By speedemongtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-08-2009, 02:30 PM
