Thread: 1997 GTP doner transmision
Results 1 to 6 of 6
  1. #1 1997 GTP doner transmision
    SE Level Member mxcobra's Avatar
    Feb 2019
    CO
    I got me a doner car its a 1997 buick riviera SC 3800 The engine is good which i am using. But does anyone if the trani matches up. I am not sure the gearing is the same., and if the performance shift feature of the GTP will work with this tramsmision?
  2. #2 Re: 1997 GTP doner transmision
    should be all the same. the hd trannys on the sc engines are the same gearing, perf shift will work.
  3. #3 Re: 1997 GTP doner transmision
    Feb 2019
    CO
    thanks... I hope so, because i'm swaping it all in one shot this weekend!
  4. #4 Re: 1997 GTP doner transmision
    Oct 2014
    portland oregon
    good luck... remember take a frosty beverage break.. maybe 2 or 3.. takes the edge off before you get super pissed
    Sent from my SM-N920V using Tapatalk
  5. #5 Re: 1997 GTP doner transmision
    Feb 2019
    CO
    Yeah going to need one of those beverage about right now, just smashed my thumb in between the idler pulley and the alternator. Immediately after the frozen idler pulley bolt snapped.
  6. #6 Re: 1997 GTP doner transmision
    Oct 2014
    portland oregon
    No bueno bro. food for thought.. It's always a good idea to pb blaster anything with threads the day before you man handle bolts.. Good news tho. Your man card checks out
  1. Turbo upgrade?
    By GHOSTOWLGRID in forum Wanted To Buy - Parts
    Last Post: 01-12-2015, 10:56 AM
  2. 3rd to 4th transmision issues
    By Hamnjelly in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-05-2011, 05:09 PM
  3. transmision slipping
    By victorca1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-28-2009, 09:06 PM
  4. transmision ??
    By french080 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-21-2009, 07:54 AM
