I have built plenty of these and they came in a lot of the mid 80s GM cars and were even used up to almost current date in a few of the smaller cars like the Cavilier and Sunfire. While they are very light, reliable, and inexpensive they also do not have overdrive which will hurt highway fuel economy. On the inside the appear pretty fragile but do handle their share of power. The most common problem on this transmission is the TCC solenoid failing which causes lockup to stick on once the transmission warms up. Unplugging the TCC plug on the trans case will be a quick fix to keep your car from dying while pulling up to a stop but replacing the solenoid is the correct fix as no TCC operation will cause the trans to run hot and hurt highway gas mileage.
