Was looking into an hp tuner for my gtp was wondering if you can change horsepower and torque? Been reading through a bunch of posts and didn't see anything about changing horsepower or torque
we have all been upping our horsepower and torque levels by huge numbers. most people make about 500 hp with hp tuners because that is the happy spot for the transmission
Some** power can be gained. But not much tuning the pcm when you add parts is what optimizes the power making but In general terms mechanical parts make the power
Under the engine section, there are a few options. But, you want to pick the last one, which reads horsepower. Once opening the tab, you will see one box you can change. For a 97-03 GTP, you will see "240" entered into it. Change it to whatever horsepower you'd like.
Under the transmission, again, go to the last tab, labeled torque. Same drill. Change the stock "280" to whatever you'd like.
Tuning is really easy once you figure this out.
Ugh.....If only GTPower had posted that advice when I started. Its all so clear now.
Subed for lulz
Go into the high and low octane timing tables. Change every cell to 30. Your horsepower will be 10 times that, as the number means a tenth of the HP the car produces at that level. If you really wanna feel extra power, pay attention to the cells at the far and bottom right of the table. Change them to 45.
Wow, wish I had known this!!! I wasted all that money on my turbo!
I don't think there is a "Max" KR... plus doing that adds a load of power? Jeeze, didn't you know. I run like 50 in the bottom right cells. Woo! got like 600wHP
If only I was at home
