Thread: 04 gt l32 swap. which computer do I have
Results 1 to 8 of 8
  1. #1 04 gt l32 swap. which computer do I have
    Mar 2014
    Angola, IN
    So I recently purchased a 04 grand prix gt with a blown l32 in it. I purchased a new(used) l32 and replaced the old engine. It runs good but if u try to hit boost it cuts out. Pretty sure I have the l32 map sensor so not sure if it may be that I have a gt computer still. Don't want to "beat" on it till I know I have a good computer for the l32.
  2. #2 Re: 04 gt l32 swap. which computer do I have
    your gonna need the pcm tuned.
    take the sc belt off till you get that.
    so im reading you right. it was n/a now its supercharged right?
  3. #3 Re: 04 gt l32 swap. which computer do I have
    Mar 2014
    Angola, IN
    Yes it's a gt body. Gtp engine swap and built tranny. I'm currently not driving it so should be good. I have a receipt for the built tranny from triple edge performance and it says tune highly suggested before driving aggressive. I'm guessing he never had it tuned lol.
  4. #4 Re: 04 gt l32 swap. which computer do I have
    id get a tuned pcm then. seems like you bought someone's failed up grade.
    you need to make sure the trans gears are set right in the pcm. the trans tuning is done via the pcm. n/a tranny and super charged HD trannys have different gears.
  5. #5 Re: 04 gt l32 swap. which computer do I have
    Mar 2014
    Angola, IN
    Yea the transmission shifts perfect so far on the back roads I have taken it down. Havnt got in the highway or anything. So should I order one from zzp or some site like that or is it the same to tune the one I have? Not sure if a tuner can access those easier however u want to put it. Also the fans stay on for 30 to 60 seconds after I shut it off is that a stock thing too or just with reprogrammed pcm`s.
  6. #6 Re: 04 gt l32 swap. which computer do I have
    maybe it is tuned then. (how well who knows) fans only stay on key off if its been tuned.
    maybe you got a simple vac leak or something then.
  7. #7 Re: 04 gt l32 swap. which computer do I have
    Mar 2014
    Angola, IN
    Yea that's what I was confused about. I had a 99 gt I swapped and got a tuned pcm and everything was good so I somewhat know about this stuff. Just got the last guys project and finished it so not sure about some stuff. The dic also isn't showing miles like the computer or wiring is messing up. U go to press a button and abs, traction control, and other stuff pops up.
  8. #8 Re: 04 gt l32 swap. which computer do I have
    your miles are stored in the dic. not the pcm. double check the grounds. but then again, this is a car you got not running, so it hard to see or tell what was f ed up before you got it, or if you caused something with the engine swap.
    if you were to change the dic, you have the donor cars miles showing.
  1. Computer?
    By 94grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2014, 10:26 AM
  2. l67 swap computer communication problems
    By tcal1011 in forum Introductions/Noob Questions
    Last Post: 09-23-2013, 07:54 AM
  3. How to tell what computer goes to what car?
    By neel2008 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2011, 11:49 PM
  4. Need Computer Help Please
    By danielle15 in forum Off Topic Discussion
    Last Post: 08-10-2011, 08:13 PM
  5. Need Computer Help
    Last Post: 04-06-2008, 11:58 PM
