Thread: 1990 Grand Prix turbo, Max boost tune?
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: 1990 Grand Prix turbo, Max boost tune?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by GHOSTOWLGRID View Post
    The srock boost is 11 PSI?
    I find it hard to believe.
    My car is one of the lucky ones with the bad gauge cluster. So i dont get any correct readings.
    So real time tuning, i burn it then install. Then adjust tune through the OBD1 port under the dash?
    Im not quite understanding that.
    I will probably like the emulation because im new to this and i am assuming it will be easier because i can adjust it as i go along.
    the log data will come from the apu and the obd 1 cable. when you are RRT the APU acts as the chip. then you burn the new chip with the data you stored on the apu and disconnect the apu from the ecm and install the chip. you cant flash the computer from the obd1 cable. only log through it. so after you burn the chip and install it in the computer that is the end of adjusting things. unless you removed the chip and hook the apu back up.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  2. #22 Re: 1990 Grand Prix turbo, Max boost tune?
    Jan 2015
    ohio
    Quote Originally Posted by NebTurboST5 View Post
    Cool, so technically, I can run it off the laptop all the time if I really wanted? (I dont want to, that would be a fun "look what I can do" type thing). lol
    I did forget to ask a very important question.
    Will this chip function for me?
    https://www.moates.net/c2-sst-27sf51....html?cPath=26
    I found the adapter, I forgot to verify which chip I need, I do not want to reflash the stock chip due to keeping a backup.
    Plus, I dont think the stock chip can be reflashed even if I wanted to.
  3. #23 Re: 1990 Grand Prix turbo, Max boost tune?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    that is the chip you need. before you get balls deep i would suggest some reading on obd1 tuning forums.
  4. #24 Re: 1990 Grand Prix turbo, Max boost tune?
    Jan 2015
    ohio
    Yah, I have been reading them for a while.
    I have an idea of what things should be based on what I read but I'm still lost on a few things, but I have no experience with doing this yet.
    Its like chopping a tree down with an axe, you watch videos and know how it should be done, but when you try it yourself, it doesn't work to well because you do not have any practice or experience on exactly how it should be done.
    Basically, I have to learn by trying it, thats why it seems like I am jumping right into this.
  5. #25 Re: 1990 Grand Prix turbo, Max boost tune?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    often the best way to learn. i would also suggest reading up on moates site lots of good info there.
  6. #26 Re: 1990 Grand Prix turbo, Max boost tune?
    Dec 2014
    Can
    go to w-body.com and find the member "turbo v-sick" his name is Adam and he will set you up with a tune for your car!
  1. 1990 Grand Prix Mclaren 3.1 Turbo
    By pontiacguy86 in forum General Grand Prix Discussion
    Last Post: 07-28-2013, 02:23 PM
