Thread: The defacto guide to tuning your car for e85.
Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 161 to 180 of 225
  1. #161 Re: The defacto guide to tuning your car for e85.
    Kemmerer, Wyoming
    i'm going to switch to 100% ethanol, should be interesting to see what difference it makes at the drag strip. I ran a 9.77 best time on E70.
  2. #162 Re: The defacto guide to tuning your car for e85.
    Kemmerer, Wyoming
    pure ethanol here I come, for the record it's denatured with sulfur, so not pure, but still E100.
    any idea what cylinder gain I should use?
  3. #163 Re: The defacto guide to tuning your car for e85.
    Apr 2015
    Columbus, OH
    I would say around 36. It's about a 20% increase over the change from regular e10 to e85.
    Top Swapped 01 Imp
  4. #164 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    If Frosty is still here, Do you have the address to that Base Fuel > Crank > Coolant temp???? HPT support will not convert a bin for me. In order for them to add it to the HPT Editor they need the address. (Whatever that is) any help would be appreciated.
  5. #165 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Stoich is available to set on my 07 so I may try that. I’ve tried all the other setups and it drives like shiiiiiit during wot. I can’t figure this E85 crap out. I have the e85 pump and 60# injectors, 3.0 pulley, 85mm maf. Any suggestions?
  6. #166 Re: The defacto guide to tuning your car for e85.
    Apr 2015
    Columbus, OH
    You don't want to just set stoich. Leave it at 14.7. Are you logging with a wideband and adjusting your MAF?
    Top Swapped 01 Imp
  7. #167 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Ok so leave stoich alone? I will put it back to 14.7. I do have a wideband logging as well as ability to change maf settings. I do have a 85mm maf in there.
  8. #168 Re: The defacto guide to tuning your car for e85.
    Apr 2015
    Columbus, OH
    Yeah. Then just follow this guide for rest of settings. If it's running crappy up top, how's your fuel?
    Top Swapped 01 Imp
  9. #169 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I can’t do the cold start part with tiny tuners. I can’t get my hptuners switched over to a bin file.
    I’ll try to follow this exactly again and see what I come up with. :/
  10. #170 Re: The defacto guide to tuning your car for e85.
    Apr 2015
    Columbus, OH
    All your doing is enter your inector data, cylinder gain to 1.2-1.3 and tune like normal. You don't need tiny tuners.
    Top Swapped 01 Imp
  11. #171 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Ok so I screwed up getting bigger injectors. Installed and ready to go. Does anyone have the procedure to get this running?
    I put on Deka injectors, 3.0 pulley, and a high flow pump.
  12. #172 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Sorry I can’t follow along very closely. I am going through a brain procedure 3x a week now.
  13. #173 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I’m trying to find the Siemens Deka settings. No luck.
  14. #174 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    So just cylinder gain adjusted to 1.3 and then all the other tuning, like normal????
  15. #175 Re: The defacto guide to tuning your car for e85.
    Apr 2015
    Columbus, OH
    You need to first put in the injector flow rate for the dekas. Then, yes, cylinder gain and tune the MAF like normal. What have u done so far? Is the car running, idleing?
    Top Swapped 01 Imp
  16. #176 Re: The defacto guide to tuning your car for e85.
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    I finally got a wideband hooked up on my regal , and on e85 im seeing Gasoline AFRs, Stoich is still set to 14.7 in the tune. Should i adjust that down to 9.7 for the e85?
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  17. #177 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Bandook. What are the numbers for the Deka injectors?
    It’s idling with a hard start. I have only put the gain to 1.3. That’s the only thing in the tune that I have changed. I need the other settings.
  18. #178 Re: The defacto guide to tuning your car for e85.
    Kemmerer, Wyoming
    don't touch the stoich, I ran though this earlier in this thread I think, or someplace on here, afr is afr regardless of fuel type. you are making it more complicated than it needs to be.
  19. #179 Re: The defacto guide to tuning your car for e85.
    Sep 2014
    Richmond Virginia
    Rickisrad
    What injectors do you have? I set my 80s by caclulating the ratio between stock and those.
    stock is 32 iirc and mine are 80s The 80s are roughly 2.5 times bigger than stock, so i multiplied the injector flow rate by 2.5 and got a nice starting point.
  20. #180 Re: The defacto guide to tuning your car for e85.
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by SgtMarshal View Post
    thats good to know, I was afraid i was beating my car with bad fueling. I keep seeing these guides that say stoich for e85 is 9.6 and that WOT should be 7.7-8 and i freaked a little . Even my mustang is showing 9 on its wideband. for ex https://www.ecmtuning.com/wiki/e85fuel
  1. HKS: Beginners guide to tuning
    By matt5112 in forum General Tech Discussion
    Last Post: 09-22-2012, 10:09 AM
  2. Gary's tuning guide?
    By Sandman in forum PCM Tuning
    Last Post: 03-23-2011, 06:53 PM
  3. gtp buying guide
    By windycitygtp in forum General Tech Discussion
    Last Post: 01-18-2009, 09:09 PM
  4. The Compleate Fuel Economy Tuning Guide
    By TDCRacing in forum PCM Tuning
    Last Post: 07-09-2008, 11:43 AM
