Thread: North Dakota Launch Control
Results 1 to 8 of 8
  1. #1 North Dakota Launch Control
    SE Level Member lightfoot__'s Avatar
    North Dakota
    The title says it all. In case you don't catch it right away the pt is messed up in reading the gear. Also, last hint, 0-78 and never broke 5,000 rpm and was WOT the whole time
    12312008_163003 from lightfoot3b -- Scan Depot dot net
    Old specs **Alt. rewire - Custom CAI - 3.15-3.4-3.5 MPS - NGK TR6 - PT Tuning In Progess - Ported S-Charger - DPP Headers - Custom 3" exhaust - SSIC**
  2. #2 Re: North Dakota Launch Control
    TDCRacing
    Guest
    Quote Originally Posted by lightfoot__ View Post
    I'm not understanding exactly what you're asking.
  3. #3 Re: North Dakota Launch Control
    North Dakota
    Quote Originally Posted by TDCRacing View Post
    No question. Just showing how I programmed in a 2nd gear start for the "2" position on the transmission.
  4. #4 Re: North Dakota Launch Control
    TDCRacing
    Guest
    Oh ok I see now lol.
  5. #5 Re: North Dakota Launch Control
    Oklahoma
    Moved to the correct area.
  6. #6 Re: North Dakota Launch Control
    Barksdale AFB, LA
    Care to share how you accomplished this?
    2009 Subaru Impreza WRX STI
  7. #7 Re: North Dakota Launch Control
    North Dakota
    Quote Originally Posted by Sabrewings View Post
    Sure! On the PT under transmission there are separate tables for each position the transmission can be in (1-2-3-D). I Changed the settings under DriveLow2(2 on the indicator). I changed the 1-2 upshift table to 0mph on the whole table, meaning anytime I'm at or over 0 be in 2nd gear. Then the 2-1 downshift table (under DriveLow2) I changed all the values to 255, meaning anytime I'm under 255 don't go to 1st gear.
    Pretty sure I explained that right (because my pt is in the car with the "car" laptop.
  8. #8 Re: North Dakota Launch Control
    Barksdale AFB, LA
    Makes sense. I had an idea that you just adjusted the shift points, and that confirms it. Nice.
    I've been meaning to look in to this. Both of my pickups when you put it in "2", it was in 2nd gear until it couldn't rev any higher, and then it shifted. I hate how our cars use 1st and 2nd.
    Thanks.
  1. How to launch?
    By keenan00gtp in forum Track Sessions and Kills
    Last Post: 11-01-2008, 11:39 PM
  2. How not to launch off the line
    By BADAZGTP in forum Off Topic Discussion
    Last Post: 07-29-2008, 04:31 PM
  3. !!?best Way To Launch?!! (traction Control)
    By BLACKEDOUTGTP in forum Track Sessions and Kills
    Last Post: 07-29-2008, 12:20 AM
  4. how to launch
    By 1badgp in forum Track Sessions and Kills
    Last Post: 06-30-2008, 03:30 PM
  5. Dodge Dakota Maintenance
    By TyroElite in forum Off Topic Discussion
    Last Post: 01-28-2008, 09:29 AM
