Thread: NA vs SC PCM
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 64
  1. #1 NA vs SC PCM
    Mar 2014
    Tucson
    Quick question... Is there a difference in the PCM's from the NA or SC engines?
    I ask because I have a spare JY PCM from a '99 NA Grand Prix that I want to use as a donor for my "tuned" PCM in my '00 GTP.
    I want to keep my stock '00 PCM untouched, as a backup.
  2. #2 Re: NA vs SC PCM
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Nope, no difference except the bin thats written on it. Your 99 n/a pcm will work for what you have planned.
  3. #3 Re: NA vs SC PCM
    Mar 2014
    Tucson
    Ahh, yes! Money well spent then.
    Looking forward to jumping into the tuning game in the near future.
    Thanks!!
  4. #4 Re: NA vs SC PCM
    Physically they are the same but the programming in each are different like he said.
    So you can't just plug the 99 NA computer into the GTP car and make it run, you will have to write a GTP file into that NA computer.
    So depending on what tuning software you are using will make or break if you can overwrite it.
    I am pretty sure with HP Tuners you can't write a S/C file onto a NA computer, but maybe you can.
  5. #5 Re: NA vs SC PCM
    Mar 2014
    Tucson
    Not sure if my terminology is correct, bare with me. I was planning on taking the bin file from my stock gtp pcm and writing that to my spare pcm and using that as a starting point for tuning. Was also planning on using HP tuners.
    Maybe one of the tuning guru's can confirm this will work? Or not?
  6. #6 Re: NA vs SC PCM
    The Boss Iceman6669's Avatar
    Jun 2011
    It can be done. Not super sure with HPT though.
    2011 F-150 Yote powered
  7. #7 Re: NA vs SC PCM
    if you unlock your stock to read the file you then have to unlock the other one to write it. So you have to use twice the credits.
  8. #8 Re: NA vs SC PCM
    Mar 2014
    Tucson
    I guess I didn't think about that. Seems like a bad plan. Or a costly on, at least.
    Maybe I'm getting ahead of myself, but ultimately I'm just wanting to use the na pcm as a core to tune for the gtp. Sounds like its doable in theory. Just might be an issues using HP tuners.
  9. #9 Re: NA vs SC PCM
    Mar 2014
    Tucson
    Just did a little reading, and it looks like we're basically after the same thing.
    http://www.grandprixforums.net/threa...oning-your-PCM
  10. #10 Re: NA vs SC PCM
    Feb 2009
    flintnasty MI
    You cant swap operating systems with HPT...
    Get a DHP and throw your HPT in the trash. I own one, use it often, and hate it with such a passion i cant put it into words.
  11. #11 Re: NA vs SC PCM
    Mar 2014
    Tucson
    I thought DHP was dead. (?)
  12. #12 Re: NA vs SC PCM
    Feb 2009
    flintnasty MI
    Quote Originally Posted by BrandonHall10 View Post
    why? they are illegal to be sold used or something?s
  13. #13 Re: NA vs SC PCM
    Mar 2014
    Tucson
    I guess not. (?)
    My only experience with purchasing software is for cad/cam design, cnc programming type software. That stuff is not re-sellable. You even have to pay maintenance fees to get updates and support.
    All that just to say, I didn't know you could buy a "used" tuner.
  14. #14 Re: NA vs SC PCM
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    You can definitely buy a used tuner. You can also flash a SC bin file to an NA PCM. My 00 bonneville SLE thinks its an 01 SSEI as far as it knows. Was done with HPT.
    04 GTP -HAI, 1.9 rockers.
  15. #15 Re: NA vs SC PCM
    Mar 2014
    Tucson
    Quote Originally Posted by SnowTh1ef View Post
    Good deal! That's exactly what I'm after. Maybe I shouldn't have said I wanted to "clone" my stock pcm. I just want to use the NA pcm, that I have on the shelf, as a core for tuning in the GTP. Leaving the original untouched. Looks like it shouldn't be to hard to find a stock bin file for it either, so I won't have to read it from my original pcm.
    Like I said, I'm not there yet, but I like to kind of know what to expect before I get there!
    Hoping to be able to split cost on tuner with a brother-in-law who has an '02 Regal GS.
  16. #16 Re: NA vs SC PCM
    Christ Scott...learn what you are talking about.
    All he has to do is have both unlocked. Say he unlocked full year 99 and full year 00, this is no worries at all. Flash and smile... poof. If not, then the DHP would make it easier.
  17. #17 Re: NA vs SC PCM
    Feb 2009
    flintnasty MI
    For less than $500*
  18. #18 Re: NA vs SC PCM
    True.. and yet I can't tune my 2000 truck with it also. Each has their positives and negatives.
  19. #19 Re: NA vs SC PCM
    Feb 2009
    flintnasty MI
    For $500 you could....
  20. #20 Re: NA vs SC PCM
    Bastard Reptile's Avatar
    Kansas City, MO
    This sh*t drives me crazy. There's absolutely nothing wrong with having HPT. Just because you have a personal grudge against it doesn't mean you have to tell someone to abandon it at every chance you get. I also have both, and like both for my own reasons. That being said, the only thing that HPT does not do for me that I'd like is modifying the PS switch settings, other than that, it's a friendlier system than DHP all around.
