Thread: flashing in another year bin into 04 monte
Results 1 to 14 of 14
  1. #1 flashing in another year bin into 04 monte
    GT Level Member jdmgtp's Avatar
    MI
    I noticed there is no way to disable cat diagnostics on the 04 monte carlo. I found the 03 doesn't have it either, is it possible to flash an 02 monte bin into an 04 monte? My only other option for this car is to run it in open loop but the 04's give goofy command a/f numbers
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  2. #2 Re: flashing in another year bin into 04 monte
    Banned
    Jan 2013
    Colorado
    is hp tuners available for this car?
  3. #3 Re: flashing in another year bin into 04 monte
    MI
    Yes
  4. #4 Re: flashing in another year bin into 04 monte
    Banned
    Jan 2013
    Colorado
    hp should be able to disable that then
  5. #5 Re: flashing in another year bin into 04 monte
    MI
    The car was originally tuned with hptuners, pretty sure there's no way to turn it off
  6. #6 Re: flashing in another year bin into 04 monte
    MI
    Unless you know something i don't
  7. #7 Re: flashing in another year bin into 04 monte
    Banned
    Jan 2013
    Colorado
    hmm, sorry then
  8. #8 Re: flashing in another year bin into 04 monte
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    tiny tuner
  9. #9 Re: flashing in another year bin into 04 monte
    Not really anyway to turn it off. Not sure I'd put a 02 file in a 04 car, sounds like a waste of money with HPT.
    Otherwise why not just plug the rear o2 in and make it further away from the exhaust gases.
  10. #10 Re: flashing in another year bin into 04 monte
    MI
    Quote Originally Posted by 231FUN View Post
    tiny tuner
    its not in tiny tuner for the 04
    I wouldn't use hpt to flash it in... I have dhp too.
    I'm just going to run it in open loop, problem solved.
  11. #11 Re: flashing in another year bin into 04 monte
    nevermind
  12. #12 Re: flashing in another year bin into 04 monte
    Dec 2011
    Ontario,Canada
    04 Monte...thats still a series 2 l67 return style fuel system is it not, only thing differnt should be the trans settings for 03+ trans?
    Tiny Tuner is the only way to turn off cat diagnostics in any 01+ car.
  13. #13 Re: flashing in another year bin into 04 monte
    MI
    It's not in the 04 file, take a look
  14. #14 Re: flashing in another year bin into 04 monte
    May 2008
    Schuyler, NE
    I don't believe you can flash an older file on the MC's because some of the gauges and interior lights may not work. From what I've read.
    A buddy had a 2000 monte that he top swapped, and I don't think he could run an 04 file, for that reason.
    Your best bet is to probably send the bin to the guys at TT, and see if you can get one of them to modify it.
  1. Last year Hoffman Estates, IL Meet. Do it again this year!
    By colindunn in forum Shows and Events
    Last Post: 09-04-2012, 05:51 AM
  2. Swapping Trans, year to year differences?
    By ColinWilson1980 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-08-2011, 12:41 PM
  3. Abs flashing
    By GTPJAY in forum Brakes/Suspension/Chassis
    Last Post: 04-16-2010, 10:50 AM
  4. Flashing SES?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-04-2010, 02:57 PM
  5. Flashing the PCM
    By Freebeer187 in forum General Tech Discussion
    Last Post: 07-22-2008, 10:47 PM
