Thread: Cruise disabling at 60mph
Results 1 to 12 of 12
  1. #1 Cruise disabling at 60mph
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Tracking down this problem. No codes. No adverse driving problems. Set cruise it works up until 60mph where it will set and shut off from a second to a few seconds later
    Our TAC module is built inside the throttle body and it has a dedicated VSS wire from pcm to the throttle body. Tech 2 cruise history shut down shows "Wheel speed to high" after speaking with diagnostic Hotline that's because the TAC module sees a speed that's to high for cruise to set (not a wheel bearing issue like I originally thought, which all work perfect anyways)
    With the tech2 unfortunately I cannot see the mph it's just not an option. I'm about to try a different throttle body to make sure it's not an issue internally.
    Diagnostic Hotline also mentioned 2 cases of where the tune was a direct effect of an aftermarket tune. I'm pretty sure I had this issue before I started tuning with hptuners..
    Anyone have any thoughts?
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #2 Re: Cruise disabling at 60mph
    It's not because of the tune. My cruise works fine
  3. #3 Re: Cruise disabling at 60mph
    Oct 2011
    MI
    I was just curious if anyone else has experienced it. I'm about to slap on my extra tb and see if it cures it
  4. #4 Re: Cruise disabling at 60mph
    Kemmerer, Wyoming
    My cruise control wouldn't work at all until I took it to the dealership. I dont remember what they checked but they said it was out of adjustment, which, was an easy and cheap fix.
  5. #5 Re: Cruise disabling at 60mph
    Oct 2011
    MI
    Nothing to adjust on 04+
  6. #6 Re: Cruise disabling at 60mph
    Oct 2011
    MI
    Also tried a new throttle body same problem.
  7. #7 Re: Cruise disabling at 60mph
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    My 05 GT cruise control randomly shuts off and will not also stay engaged occasionally . Any ideas where to start looking?
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  8. #8 Re: Cruise disabling at 60mph
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Hmmm... how much brake pedal travel disengages cruise control on this car? Maybe there is something too sensitive there.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  9. #9 Re: Cruise disabling at 60mph
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    Have you adjusted the speedometer in your tune for a different tire size?
    Email all inquiries to willoverkill@gmail.com!
  10. #10 Re: Cruise disabling at 60mph
    Jul 2013
    London
    Yo did you get this sorted? Would like to know how. I'm having a similar problem.
  11. #11 Re: Cruise disabling at 60mph
    gardner,mass
    I had the same issue, and it was because of my tune. It was because my cruise afr was set to rich and i noticed what would happen was when my wideband would read like 11-12 afr my cruise would shutoff. I ended up setting my maf hz table to stock till about 7k+ and it fixed it.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  12. #12 Re: Cruise disabling at 60mph
    Knoxville, TN
    Quote Originally Posted by Ginseng View Post
    Huh, were you running full-time open loop? You'd think the PCM would adjust fuel trims to compensate, unless it was pegged full lean and still not getting there.
  1. Service Engine Soon Light At 60mph
    By Alcatraz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2012, 09:11 AM
  2. GTP shakes between 40-60mph
    By quigs in forum Brakes/Suspension/Chassis
    Last Post: 02-13-2012, 10:28 PM
  3. Bad vibration when driving at 40mph to 60mph!! Help
    By nickdemio in forum Brakes/Suspension/Chassis
    Last Post: 03-27-2011, 09:56 AM
  4. My 30MPH to 60MPH Video
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 11-13-2010, 10:39 AM
  5. Shaking Between 40-60MPH while Throttling
    By nathangartz in forum Tires & Wheels
    Last Post: 08-10-2009, 04:23 PM
