Thread: Need serious help for trouble code p0452
Results 1 to 9 of 9
  1. #1 Need serious help for trouble code p0452
    SE Level Member Joevolino's Avatar
    Jul 2014
    Long Island
    Hey guys, so I'm new to this forum.
    I have a 2001 Pontiac grand prix 4 door 3.8L GT
    I have had my check engine light on for quite a long time now. My dad has an OBD reader so I connected it and it came up with trouble code P0452. After all the research and finding out its the "Fuel tank pressure sensor low voltage" we tried replacing the gas cap and fuel tank pressure sensor and still no luck. Ive read i need to test the voltage on the wiring and such, and we did that and it seemed to be fine (that is if we did it right), but whats my best course of action? This is driving me crazy and I cant seem to figure it out.
    Thanks guys
    -Joey
  2. #2 Re: Need serious help for trouble code p0452
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    P0452 is not the fuel pressure sensor, it's the evaporative emission control system. There's a solenoid near the coil packs. Check the wiring going to it. It's called a purge valve. Inexpensive to replace.
  3. #3 Re: Need serious help for trouble code p0452
    Jul 2014
    Long Island
    p0452 means low voltage going to the fuel tank pressure sensor no? Because from previous diagnostics everything says it could be a faulty FTP Sensor (which it couldn't be because I replaced it twice) and/or the wiring going to it. I guess I'll try replacing the purge valve to see if that does anything
  4. #4 Re: Need serious help for trouble code p0452
    No
    http://www.obd-codes.com/p0452
    Take a read for yourself. Says evap, not pressure.
  5. #5 Need serious help for trouble code p0452
    Jul 2014
    Long Island
    I replaced the purge valve and still no luck, the light came right back on after resetting it
  6. #6 Re: Need serious help for trouble code p0452
    Potential causes for this DTC include:
    Failed fuel tank pressure sensor Harness to the sensor has an open or short circuit Faulty electrical connection to the FTP sensor Cracked or broken vapor line to the vacuum canister Cracked or broken positive vapor line to the tank Plugged line Leaky gasket at the fuel pump module Gas cap left loose resulting in a loss of vacuum Pinched vapor line
    Read more at: http://www.obd-codes.com/p0452
    Copyright © OBD-Codes.com
    keep looking. check over the wires to the purge solenoid, and the canister tank in the rear quarter panel.
  7. #7 Need serious help for trouble code p0452
    Jul 2014
    Long Island
    Okay ill have to get it on a lift. I heard something about some sort of smoke machine that tests for leaks in the vapor lines?
  8. #8 Re: Need serious help for trouble code p0452
    you can make one, search you tube. but it says low voltage. id look for bad wires to the solenoid first.
  9. #9 Re: Need serious help for trouble code p0452
    gardner,mass
    Yea spend a buck on a cigar and blow into some lines.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  1. Finished build now got a P0452 code..
    By GTP89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2013, 05:57 PM
  2. Code P0452
    By Dr Cedric in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 12:07 AM
  3. Trouble code
    By Gerryk in forum General Grand Prix Discussion
    Last Post: 01-30-2013, 02:47 PM
  4. Trouble code
    Last Post: 01-02-2013, 06:38 AM
  5. Trouble Code Help
    By TheRoadWarrior in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 07:26 PM
