Thread: Aeroforce
Results 1 to 15 of 15
  1. #1 Aeroforce
    Dec 2012
    Canada
    I just purchased and rough installed my new Aeroforce Gauge in my 02 GTP to make sure it was working but now need to make the install more permanent, does anyone have any suggestions other than a pillar pod as I only intend to have this one gauge?
  2. #2 Re: Aeroforce
    HUD pod from ZZP
    Or attach it to the console area
    04 Comp G.
  3. #3 Re: Aeroforce
    Dec 2012
    Canada
    Do you have any pics of how this is acbieved
  4. #4 Re: Aeroforce
    Omaha, NE
    If you have an 04+, you can seal a plate on the front of the console cubby with a hole for the gauge.
  5. #5 Re: Aeroforce
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Here is the HUD Pod&nbsp;<br><br>
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  6. #6 Re: Aeroforce
    Dec 2012
    Canada
    Thanks for the great pic, with my car being an 02 how does the HUD attach to my dash?
  7. #7 Re: Aeroforce
    Dec 2012
    Canada
    Also where do you run the power wire and OBD2 up to the HUD location?
  8. #8 Re: Aeroforce
    You can go up through the space around the HUD if you have one.
    The HUD pod just sits there. It's supposed to be held in place by the A pillar cover.
    My personal favourite spot for a gauge is down in the cubby in front of the shifter. It's a little less obnoxious, and easy to cover up as that Aero brightness isn't easily adjusted. Out in the country at night, it will be blinding.
    Just open the cupholder, and pull up on the trim piece around the shifter then pull it back and up. Might have to move the shifter out of park and into gear. Make sure the wheels are chalked or the parking brake is on (if it works).
  9. #9 Re: Aeroforce
    Marysville WA
    What he said ^^^^
    It all comes down to personal preference, the HUP pod was a simple solution for my needs and cheap.
  10. #10 Re: Aeroforce
    Dec 2012
    Canada
    Thanks to all for your input, I am leaning towards the cubby area for my install, I will provide more input when done.
    Hopefully after install I am able to figure out how to use this gauge!
  11. #11 Re: Aeroforce
    Florida
    I just took a hole saw to the dash!
    Aeroforce Attached Images
  12. #12 Re: Aeroforce
    Pennsylvania
    http://home.comcast.net/~warren.family/AFG.html
    Follow this... it's a really nice mount location, totally temporary if you every need to remove it, no visible wiring... it looks completely stock if you do it right.
    You can find the trim ring for like 3 bucks at Staples/Home Depot/etc
    You dont have to do ANY of that cutting that he talks about at all.
    Im jealous, I wish I could get my Aeroforce working again . It worked so nice for a few months and then started resetting one day, never was good again. I've exhausted every forum I can find, I exhausted Crutchfield support, ZZP, Aeroforce customer service, Will Overkill wont answer me about it, and neither will Intense. Nobody seems to be able to figure out what's wrong with this thing/my car. It's insane.
    Sport Edition Kv5 18x8
  13. #13 Re: Aeroforce
    Dec 2012
    Canada
    Thanks Fribo, great info but my car is an 02 GTP and it does not have the vent ball setup, your idea and gauge looks great!
  14. #14 Re: Aeroforce
    Pennsylvania
    Oops, I just realized I actually have no idea what the vents in a pre-04 look like, lol.
    Oh well, however you set it up, they're a really fun toy... have fun!
  15. #15 Re: Aeroforce
    Dec 2012
    Canada
    Thanks guys you have all given me some great info and ideas, options etc, presently at least I have my gauge functioning, these gauges really are a must have if you have a nodded car, will keep you posted on my addiction to modding
  1. Aeroforce.
    By nos4blood70 in forum Wanted To Buy - Parts
    Last Post: 12-06-2013, 05:57 PM
  2. Aeroforce
    By juiceman27 in forum Wanted To Buy - Parts
    Last Post: 07-03-2013, 03:24 PM
  3. Older Aeroforce vs newer aeroforce
    By Lishap in forum General Grand Prix Discussion
    Last Post: 04-21-2013, 01:23 PM
