Thread: 3.29 to 2.93 Tuning
Results 1 to 10 of 10
  1. #1 3.29 to 2.93 Tuning
    Oct 2011
    Puyallup WA
    Hey wanting to switch to the more highway friendly gears I have the sprockets to do it just need to know what to change in the tune...I have read the how to when going from 2.93 to 3.29...my calculated gear currently shows 3.29 so do I change this to 2.93 after switching to he 2.93 sprockets?
    08 G8 GT - exhaust Tune
  2. #2 Re: 3.29 to 2.93 Tuning
    Even on a 2.93 geared car, the calculated gear is always 3.29, there is something else that you need to change I think.
  3. #3 Re: 3.29 to 2.93 Tuning
    Florida
    You have to change the pulses per mile and also will need to change the shift points. Just find a bin from a GTP as they have the 2.93's and swap their Trans settings
  4. #4 Re: 3.29 to 2.93 Tuning
    Oct 2011
    Puyallup WA
    Thanx man! Prob won't swap the gears right away but coming up with a plan for it
  5. #5 Re: 3.29 to 2.93 Tuning
    Feb 2009
    flintnasty MI
    the method for this is different between dhp and hpt... DHP cant really do it effectively without tinytuner for most OSIDs.
  6. #6 Re: 3.29 to 2.93 Tuning
    Oct 2011
    Puyallup WA
    I will be using hpt
  7. #7 Re: 3.29 to 2.93 Tuning
    GT Level Member ls1camino's Avatar
    Laurel, MD
    In HPT there is a value that is your gear ratio...just change it and upload the file to your car.
    Also, why are you going through all of this work for a better highway gear? The money and time spent swapping the gears/chains will not be offset by your slightly improved MPG for awhile.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  8. #8 Re: 3.29 to 2.93 Tuning
    Feb 2009
    flintnasty MI
    Using the wizard in HPT requires some twiddling around.. You cant just put in the right number. Cruise the HPT forums for specifics but I know you need to put in 3.69 when switching to a 3.29 or something, so I assume its similar when downgrading.
  9. #9 Re: 3.29 to 2.93 Tuning
    Oct 2011
    Puyallup WA
    Quote Originally Posted by ls1camino View Post
    I got the 2.93 gears for free so will be just my time...I have a cam to install so motor and trans will eventually be coming out anyways...not for sure doing it but since I have the stuff for it was wondering what tuning I will have to do
  10. #10 Re: 3.29 to 2.93 Tuning
    Oct 2011
    Puyallup WA
    Ok I will take a look over on HPT
  1. Tuning
    By Pshnmeawy in forum Midwest
    Last Post: 07-21-2011, 08:02 PM
  2. Tuning help
    By MakeitLouder97 in forum PCM Tuning
    Last Post: 08-02-2010, 07:48 PM
  3. tuning
    By nicksilvergt99 in forum General Tech Discussion
    Last Post: 08-30-2009, 05:40 PM
  4. tuning on LI
    By mpiacent in forum PCM Tuning
    Last Post: 08-10-2009, 09:50 PM
