Thread: Richening up WOT afr with Dhp
Results 1 to 20 of 21
  1. #1 Richening up WOT afr with Dhp
    What do I have to do to richen the afr up to get it where I need it? I'm running around 12-12.5 right now and it's causing some KR. Thanks.
  2. #2 Re: Richening up WOT afr with Dhp
    You could go in the base afr vs ect table if it has one.
    What have you done to the tune if anything??
    The stock tune should already run the car pretty rich, around 11ish.
  3. #3 Re: Richening up WOT afr with Dhp
    I've done nothing to tune it yet. Wot I'm leaning out pretty good. I'm running ported heads, s1x, headers, and a 3.4
  4. #4 Re: Richening up WOT afr with Dhp
    Oct 2011
    Puyallup WA
    Are you able to hook your WB up to DHP? I have only used HPT with WB
    08 G8 GT - exhaust Tune
  5. #5 Re: Richening up WOT afr with Dhp
    I'm able to buy don't know how
  6. #6 Re: Richening up WOT afr with Dhp
    Its not worth it to hook the WB up to the dhp, its 10x easier to just glance at what its reading.
    And you are sure there is no exhaust leak before the WB sensor?
    Any codes on? What did you do to the rear o2 sensor?
  7. #7 Re: Richening up WOT afr with Dhp
    Oct 2011
    Puyallup WA
    Where are your LTFT at?
  8. #8 Re: Richening up WOT afr with Dhp
    No exhaust leaks pre wb. I have no rear o2. Not sure on the ft
  9. #9 Re: Richening up WOT afr with Dhp
    Oct 2011
    Puyallup WA
    When I was getting weird blips of KR up top my FT's where off because I had added 1.9 rockers
  10. #10 Re: Richening up WOT afr with Dhp
    I'm on a stock tune with ported heads s1x headers and a 3.4 so I'm sure my stuff is off I'll do a scan tonight if i get around to it
  11. #11 Re: Richening up WOT afr with Dhp
    I thought 01+ cars need the rear o2 atleast plugged in but then the cat codes just turned off.
  12. #12 Re: Richening up WOT afr with Dhp
    It's fine without it. I tuned the code out and it never gets really rich while driving or anything
  13. #13 Re: Richening up WOT afr with Dhp
    May 2008
    Schuyler, NE
    What injectors are you running?
    What is your commanded AFR?
  14. #14 Re: Richening up WOT afr with Dhp
    Being that its a stock tune, prolly 12.4, then factor in all the adders and on most cars you'll see 10.5 to 11.5.
  15. #15 Re: Richening up WOT afr with Dhp
    Stock injectors. Commanded afr says 14.7
  16. #16 Re: Richening up WOT afr with Dhp
    Look in your Base AFR vs ECT table, that where it wll go when you hit PE.
  17. #17 Re: Richening up WOT afr with Dhp
    May 2008
    Schuyler, NE
    Your injectors are too small.
    What are you commanding at WOT?
  18. #18 Re: Richening up WOT afr with Dhp
    May 2008
    Schuyler, NE
    Gee, thanks.
  19. #19 Re: Richening up WOT afr with Dhp
    I have it at 11.78 right now. It was at 12.4 It's not leaning out anymore in the upper rpms but I'll do a scan and see what my idc is and see how my injectors are looking.
  20. #20 Re: Richening up WOT afr with Dhp
    Gee, thanks.
    Hey, you asked.......
