What do I have to do to richen the afr up to get it where I need it? I'm running around 12-12.5 right now and it's causing some KR. Thanks.
You could go in the base afr vs ect table if it has one.
What have you done to the tune if anything??
The stock tune should already run the car pretty rich, around 11ish.
I've done nothing to tune it yet. Wot I'm leaning out pretty good. I'm running ported heads, s1x, headers, and a 3.4
Are you able to hook your WB up to DHP? I have only used HPT with WB
I'm able to buy don't know how
Its not worth it to hook the WB up to the dhp, its 10x easier to just glance at what its reading.
And you are sure there is no exhaust leak before the WB sensor?
Any codes on? What did you do to the rear o2 sensor?
Where are your LTFT at?
No exhaust leaks pre wb. I have no rear o2. Not sure on the ft
When I was getting weird blips of KR up top my FT's where off because I had added 1.9 rockers
I'm on a stock tune with ported heads s1x headers and a 3.4 so I'm sure my stuff is off I'll do a scan tonight if i get around to it
It's fine without it. I tuned the code out and it never gets really rich while driving or anything
What injectors are you running?
What is your commanded AFR?
Stock injectors. Commanded afr says 14.7
I have it at 11.78 right now. It was at 12.4 It's not leaning out anymore in the upper rpms but I'll do a scan and see what my idc is and see how my injectors are looking.
