Got my 04 NA GT buttoned up and running. I'm using my 01 trans in this car because it is overbuilt and will be great when i finish my l67 and drop it in. (inside the trans is 04+, I've swapped the wiring, VB and channel plate, and pump)
I dont know why, but I'm getting a code for incorrect gear ratio on my tuner when I do my scans(I own a DHP ) and when i take it around the block for a test drive it is SLAMMING from gear to gear. I know not to drive the car until it's fixed so I need to know what to change under my transmission settings. I do not know which reluctor wheel I have in the trans, all I know is that is was built by dave at TEP.
My trans has 3.29 gearing and I thought that all GTs had 3.29s from the factory so I thought it would drop in with no tuning required.
