Thread: Wideband, Histogram & HPTuners
Results 1 to 17 of 17
  1. #1 Wideband, Histogram & HPTuners
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Okay. Ive got my wideband in. i have setup the aux in user defined. i can go to histogram and i have my aem showing up, i've done the voltage correction and both the display and hp show the same.
    my problem is getting the histogram to work properly, ive tried it a hundred different ways but i cant get the afr to show up in more then one box (instead of going with the maf hz.)
    anyone have a config file i can get because i'm seriously about to flip the **** out.
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #2 Re: Wideband, Histogram & HPTuners
    Arizona
    Are you logging AFR in your table display and AFR error?
  3. #3 Re: Wideband, Histogram & HPTuners
    May 2008
    Schuyler, NE
    Yeah, make sure you have it displayed in the table.
  4. #4 Re: Wideband, Histogram & HPTuners
    Oct 2011
    MI
    I was pretty sure it's displayed I've tried everything I can think of. Guess I'll just have to keep working on it.
    The air shows up properly just only in the first box not as the hz go up. I had it working with rpm but not like what's in the getting started thread we have on the site.
    Sent from my Galaxy SIII on Tapatalk 2
  5. #5 Re: Wideband, Histogram & HPTuners
    Feb 2009
    flintnasty MI
    you shouldnt need to plot it against a histo anyway. I wouldnt worry about it.
  6. #6 Re: Wideband, Histogram & HPTuners
    Oct 2011
    MI
    How else would I adjust afr? Its running way to rich. I was just following the guide that nick made.
  7. #7 Re: Wideband, Histogram & HPTuners
    Compare the WB vs command at WOT.
    Adjust by 50% of the error until you get it right.
  8. #8 Re: Wideband, Histogram & HPTuners
    Oct 2011
    MI
    I'll do that, Any good write ups?
  9. #9 Re: Wideband, Histogram & HPTuners
    Oct 2011
    MI
    So basically go for a drive while scanning record and then adjust?
  10. #10 Re: Wideband, Histogram & HPTuners
    Arizona
    All you need to verify is your AFR error vs maf hz and AFR error vs ve get those two things in line visually scan your AFR readout at the areas your tuning for rince and repeat
  11. #11 Re: Wideband, Histogram & HPTuners
    May 2008
    Schuyler, NE
  12. #12 Re: Wideband, Histogram & HPTuners
    Arizona
    Remember there are a lot of ways to get your tune right some don't care about ve some just want mad only some prefer ve to switch to maf And some go full hybrid its just my preference to tune ve seperatley then tune maf only then enable both all the way to 8192 rpm that way I know ve never goes out of the equation and if my maf ever fails or becomes dirty my fueling will still be close
  13. #13 Re: Wideband, Histogram & HPTuners
    Oct 2011
    MI
    Who's going to the meet n greet in royal oak this weekend lol
  14. #14 Re: Wideband, Histogram & HPTuners
    Oct 2011
    MI
    I'll get it figured out just sometimes hard without someone showing me in person
  15. #15 Re: Wideband, Histogram & HPTuners
    Oct 2011
    MI
    Start scanning and reset the fuel trims. Now the commanded AFR will be steady at 14.7. With the Maf AFR histogram open, drive the car at part throttle to fill the histogram up to ~7500 hz. Try to accel & decel smoothly.
    getting my histo setup right is what I'm having issues with. I've got a bunch of Info to work with when I get home. If I can't figure it out someone at the meet has to know how to get me going.
  16. #16 Re: Wideband, Histogram & HPTuners
    Feb 2009
    flintnasty MI
    the narrowband is going to change the fuel trims to satisfy the narrowband... tuning/scanning/having a wideband is pointless as long as the narrowband wants to do things.
  17. #17 Re: Wideband, Histogram & HPTuners
    Oct 2011
    MI
    Yeah I think I'll use the open loop tuning. Unless I can just get someone to do it this weekend.
  1. KR on the Chart display but not on histogram
    By Explicit_Spade in forum PCM Tuning
    Last Post: 09-16-2011, 07:02 PM
  2. Hptuners
    By minichopper6hp in forum PCM Tuning
    Last Post: 06-07-2009, 01:26 PM
