Thread: tune for turbo setup?
Results 1 to 13 of 13
  1. #1 tune for turbo setup?
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    Anyone happen to have a bin file for DHP that is for a turbo'd car?
  2. #2 Re: tune for turbo setup?
    May 2008
    Schuyler, NE
    Going to need more details than that.
  3. #3 Re: tune for turbo setup?
    St. Louis
    Well I have a CT kit on my car, which is a 98 L67 and I just just trying to compare files and see what other people are running A/F wise, shift points, etc.
  4. #4 Re: tune for turbo setup?
    Feb 2009
    flintnasty MI
    stock works fine.
  5. #5 Re: tune for turbo setup?
    St. Louis
    just a stock file?
  6. #6 Re: tune for turbo setup?
    May 2008
    Schuyler, NE
    What injectors?
    What MAF?
  7. #7 Re: tune for turbo setup?
    Feb 2009
    flintnasty MI
    Quote Originally Posted by stlmo_gtp View Post
    just a stock file?
  8. #8 Re: tune for turbo setup?
    St. Louis
    What injectors?
    What MAF?
    I have 65# Injectors and am running an LQ4 MAF
    Already changed those values in my tune
  9. #9 Re: tune for turbo setup?
    May 2008
    Schuyler, NE
    And, do you have a wideband?
  10. #10 Re: tune for turbo setup?
    St. Louis
    yes I do when it is at idle it is around 14.7, and at WOT it goes to about 12. but I am not sure if that is lean enough for max potential because from what I have heard turbo's like leaner conditions...also I am having weird start up issues, it starts and the A/F is around 14.7 initially but then after about 15 seconds it just drops to 10.1 in park just idling and then after about another 30 seconds it goes back up to 14.7, outside air temp is in the 60's and all my start up files are at stock values so I am not really sure why it would be doing that but I do have a feeling that a part of the problem is in the tune somewhere
  11. #11 Re: tune for turbo setup?
    Feb 2009
    flintnasty MI
    turbo stuff on 93 you want to be under 11.5 afr.
  12. #12 Re: tune for turbo setup?
    St. Louis
    so closer to the range of like 10.7-11 ?
  13. #13 Re: tune for turbo setup?
    11.3-10.9, which is about what the factory tune does.
  1. Custom Turbo Setup
    By ImColeTrickle in forum Turbo
    Last Post: 02-07-2012, 01:23 AM
  2. Turbo setup
    By BoostnLSX in forum 5.3L V8 (LS4)
    Last Post: 01-31-2012, 06:12 PM
  3. Replies: 8
    Last Post: 03-22-2009, 01:39 PM
