Thread: Top Swapped L26 hpt file
Page 3 of 3 FirstFirst 123
Results 41 to 57 of 57
  1. #41 Re: Top Swapped L26 hpt file
    May 2008
    Schuyler, NE
    Quote Originally Posted by jlgp2007nc View Post
    That makes much more sense. No LQ4 yet.
    Sent from my SPH-D710 using Tapatalk 2
    Use a stock L32 MAF table then.
  2. #42 Re: Top Swapped L26 hpt file
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Ok cool.
    L32 maf
    L67 timing
    Better injector table
    Stock L26 VE
    11.0 AFR
  3. #43 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    Blah...just starting to roll onto the throttle and heard a loud knock and thud. This is going to be a pain. Can't afford a new bottom end yet.
  4. #44 Re: Top Swapped L26 hpt file
    Feb 2009
    flintnasty MI
    are you scanning commanded afr? what are your locking LTFTs? What are you using for injector constants? Do you still have the map sensors plugged in?
  5. #45 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    Commanded..no. I just know what I set.
    When ltfts finally lock in I don't see more or less than .3-.4 pos or neg. Obviously they're a little off cause I just changed everything again.
    Constants? Do you mean the flow rate vs kpa table?
    And...lol yeah the MAP sensor is plugged in still. Only one on my l26.
  6. #46 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    Injector table
  7. #47 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    Commanded added to scanner pids
  8. #48 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    ....And commanded won't shop up in logs.
    Still trimming fuel though so not leaning into boost.
  9. #49 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    Ok I've been stubborn.
    L32 MAF, but trimming for fuel trims.
    Used L67 timing then I leaned into boost a little it missed hard. RPMs fell until the engine quit. Wouldn't start. Reflashed with L32 timing. Starts right up and runs.
    Trimmed a bit more for fuel trims over 10%...
    Leaned in this morning and engine quit, wouldn't restart until after reflashing in the middle of the road.
    I remember the comment about unplugging the MAP sensor. I didn't think the car would run without it. I know for sure it won't with the
    MAF unplugged.
    So I got to work this morning and popped the plug to the MAP at idle and it didn't skip a beat so I guess I'll be doing my next scan with it unplugged.
    Is that what's causing all of my trouble though? I know for sure install of the top swap was clean. Torqued EVERYTHING that had a specification. Heads were cleaned and decked. Checked pushrod length....rocker bolts torqued, all brand new gaskets....fresh fluids. ....so ? ????????
  10. #50 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    Definitely lean
  11. #51 Re: Top Swapped L26 hpt file
    Feb 2009
    flintnasty MI
    You are kidding right? Your POS car WILL NOT F#$KING RUN WITH THE L26 MAP IN IT. F#%$^
    Unless you are really on top of things you will never "know" what your commanded is. Considering your track record in this thread, I would pay close attention to what commanded is doing.
  12. #52 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    I'm using an L67 MAP sensor. I knew now to use the stock L26 MAP. I'm not going into this completely blind I did try to research before messing around I'm not that dumb. Sorry if I'm annoying you guys, just looking for some help...
  13. #53 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    I've been looking around at all of the data on my HP Tuners and there's an option for commanded afr, but not showing values for it in my scans.
  14. #54 Re: Top Swapped L26 hpt file
    Feb 2009
    flintnasty MI
    low res commanded afr I think is the hpt equiv.
    You cant use either of them. The only case you can use a 2 bar is if you get both of the 2 bar map sensors and wire them in.
  15. #55 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    [QUOTE=darkhorizon;1037187]low res commanded afr I think is the hpt equiv.
    Used that option...shows up on the chart as a label, but no data fills that spot.
    You cant use either of them. The only case you can use a 2 bar is if you get both of the 2 bar map sensors and wire them [QUOTE]
    Unplugged the MAP and she operates much smoother using the MAF. Now is it safe to run without the MAP until my new sensors come in?
  16. #56 Re: Top Swapped L26 hpt file
    Feb 2009
    flintnasty MI
    Why bother running 2 map sensors? Its a huge pain in the ass to setup (you have to clamp the baro sensor somehow), and does nothing to help. What made you assume that it was unsafe?
  17. #57 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    Ha! All I needed to hear! Lol...
    Really though the MAP was there before the swap and I wanted to keep as much tge same as possible providing it all operated correctly.
    Ran great this morning off of only the MAF so I'm just going for it. Even AFR wasn't dead on but much closer.
    So thanks a ton guys, darkhorizon.
    And my car is not a POS!!!
    Not yet.
  1. need a dhp bin file for 99 gtp
    By onalky87 in forum PCM Tuning
    Last Post: 06-18-2012, 11:32 PM
  2. Need a Bin File
    By SerenityGTO in forum PCM Tuning
    Last Post: 06-08-2011, 01:14 PM
  3. need dhp bin file
    By nascartech in forum PCM Tuning
    Last Post: 11-20-2010, 11:50 PM
  4. Transmission bin file to another bin file?
    By Pure2sin in forum General Tech Discussion
    Last Post: 11-10-2010, 07:11 PM
  5. DHP file
    By TheOtherNick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-25-2009, 02:51 PM
