Thread: Top Swapped L26 hpt file
Results 21 to 40 of 57
  1. #21 Re: Top Swapped L26 hpt file
    I thought the '04+ timing table was more aggressive than the '97-'03 L67 tables...if so, that'd be a place to start. I'd still rather not have less than 16*...
  2. #22 Re: Top Swapped L26 hpt file
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    You can email it to me, and I'll take a look at it, if you want. Send the file that you are running too.
    nick_04sc@hotmail.com
    Thanks dude. Soon as I get a break I'll send it.
    Sent from my SPH-D710 using Tapatalk 2
  3. #23 Re: Top Swapped L26 hpt file
    May 2008
    Schuyler, NE
    Got it. I will take a look at it when I get off work.
  4. #24 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    Yeah I'm way low in my timing. started pulling some to keep the knock down.
  5. #25 Re: Top Swapped L26 hpt file
    Portland Oregon
    Email me at Desertoftherea1@aol.com and I'll shoot you the tune I'm using. It's a ZZP 1.0 variant. I have an 04 Comp G, xp cam, open cone, stock maf, cat-less headers, and 42.5's with hand ported heads.
  6. #26 Re: Top Swapped L26 hpt file
    Portland Oregon
    I can run the tune on a 3.2 pulley and premium with minimal to no knock.
  7. #27 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    But comp
  8. #28 Re: Top Swapped L26 hpt file
    Portland Oregon
    Huh?
  9. #29 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    But comp g is l32 bottom end right?
  10. #30 Re: Top Swapped L26 hpt file
    Portland Oregon
    L26. Spin a bearing in the stock L32
  11. #31 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    My scan from this morning with some help from oh4compgs injector and timing table.
    Im commanding 11.0.... so What I've been doing when I see this is mutiply my maf vs frequency table from 7000 up by 1.02...supposedly adding fuel by 2%. Theres a dead spot that I think is this red spot where I'm going from vacuum to boost where i misfire all over the place but just in this one spot and I can push passed it but I don't like the dead spot. You can even see the injector duty shut down on the rest scan.
  12. #32 Re: Top Swapped L26 hpt file
    May 2008
    Schuyler, NE
    I took a look at your files. Your injector table looks incorrect to me. It also looks to me like your car isn't going into PE, or your injector table is making it look that way.
    What do you have going on with your VE table?
  13. #33 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    Guy from intense sent me a file with "file with map scaled for L67 map sensor"....and just kind of left it at that. I thought copying it over to my VE table was what I needed to do.
    Didn't seem to make anything run easier.
  14. #34 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    I've changed the injector table. What I was looking at there was the formula given in that starting hp tuners post. It didn't look right to me either. OH4COMPG has the same injectors so I compared them and made the change. Fuel trims locked in quicker.
  15. #35 Re: Top Swapped L26 hpt file
    Feb 2009
    flintnasty MI
    if you are running a L32 file, you need to have 2 2 bar map's. If you are running a L26 you need to remove the map sensors.
    Ve table should remain stock no matter what. You cant "scale" them.
    PLEASE put the stock maf table back in, whatever you have there is completely broken.
  16. #36 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    Thank you. That's the only time I've heard that after looking forever for a specific answer. But remve the map sensor?
  17. #37 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    L26 pcm
  18. #38 Re: Top Swapped L26 hpt file
    May 2008
    Schuyler, NE
    Yes.
    I would start over, with a completely stock file. Change your IFR table to what you were sent, change your MAF if you're running a LQ4, stick in some L67 timing tables and set your commanded PE to 11.0ish.
  19. #39 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    That makes much more sense. No LQ4 yet.
  20. #40 Re: Top Swapped L26 hpt file
    Sep 2012
    North Carolina
    I appreciate all of you guys' input.
  1. need a dhp bin file for 99 gtp
    By onalky87 in forum PCM Tuning
    Last Post: 06-18-2012, 11:32 PM
  2. Need a Bin File
    By SerenityGTO in forum PCM Tuning
    Last Post: 06-08-2011, 01:14 PM
  3. need dhp bin file
    By nascartech in forum PCM Tuning
    Last Post: 11-20-2010, 11:50 PM
  4. Transmission bin file to another bin file?
    By Pure2sin in forum General Tech Discussion
    Last Post: 11-10-2010, 07:11 PM
  5. DHP file
    By TheOtherNick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-25-2009, 02:51 PM
