Thread: Power tuner issue...basic problem or my own stupidity?!
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Power tuner issue...basic problem or my own stupidity?!
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I've Installed them everyday for years. With that being said on our vehicle the module that does security bypass and locks is attached to the data line. I have never personally seen this module cause any interference problems. Especially when writing with hpt. It uses the data line to relay the message for locks or bypass but isn't continously "talking" on the data line.
    While something like the aeroforce gauge is always monitoring through data I have seen it cause communication issues (writing w/hpt as well)
    And to answer your other question you are writing to the PCM not the BCM. The PCM controls powertrain functions ex. Fans
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #22 Re: Power tuner issue...basic problem or my own stupidity?!
    Oct 2011
    MI
    It would also be likely it's attached (not in line, there'd be no reason for that) to the data line at the obd2 port. The data line is a single wire attached to every module
  3. #23 Re: Power tuner issue...basic problem or my own stupidity?!
    May 2012
    Albuquerque, NM
    Sorry, double post...
  4. #24 Re: Power tuner issue...basic problem or my own stupidity?!
    May 2012
    Albuquerque, NM
    I guess I'll write up my step by step and include screen shots and bins as suggested earlier. As of now I'm just plain frustrated. I'll have it up tomorrow most likely.
    Thanks again for the feedback.
  5. #25 Re: Power tuner issue...basic problem or my own stupidity?!
    May 2012
    Albuquerque, NM
    Sooooo, I end up trying one last thing. I change the true/false setting on the "data setting" for my fan and pow! It's working!
    Is this just a weird occurance or did I possibly have a aftermarket cooling fan set and just not notice. It looks OEM. Anyways, is it bad to change the "series II data" setting for my fans? Should I move on or should I look for a bigger issue?
  6. #26 Re: Power tuner issue...basic problem or my own stupidity?!
    May 2012
    Albuquerque, NM
    Here is my bin. The fan is working but.....the autostart and power locks/trunk is no longer working. Any ideas or thoughts?
  7. #27 Re: Power tuner issue...basic problem or my own stupidity?!
    May 2012
    Albuquerque, NM
  1. power tuner help
    By 97redrocket in forum General Tech Discussion
    Last Post: 04-07-2010, 07:39 PM
  2. DHP Power Tuner
    By 98gtpne in forum General Tech Discussion
    Last Post: 09-29-2009, 11:27 PM
  3. New power tuner
    By Deeter in forum PCM Tuning
    Last Post: 05-26-2008, 09:32 AM
