Thread: Jacked Up Fuel Trims w/Scan
Results 1 to 8 of 8
  1. #1 Jacked Up Fuel Trims w/Scan
    Outer Space
    I went from a Front PLOG, and DP to headers last week.
    Before I had good trims thanks to the MAF tune... but now I notice at idle my LTFT's are 16.4025
    So I figured that I maybe I need to do a VE Tune. When I unplug the MAF I get Lean results not pig rich like expected.
    I abandoned the VE Tune for the moment, however when scanning... on WOT I lock in at 0 every time.
    Should I just scale the %#@! out of the MAF for the idling frequencies? Or should I put a DHP BIN on there and completely start over?
    EDIT: Recent scan added RACETRACK_10-27-2008_9_26_51_A from lawngoose -- Scan Depot dot net
    02 GTP 13.6 @ 100mph - SOLD
  2. #2 Re: Jacked Up Fuel Trims w/Scan
    Banned
    oswego
    I didn't look at the entire scan because it was just wayyy to long. However from what i picked up it's not just your idle trims that are bad. Your cruising trims are also out as well As for the idling trims i would scaled them 11% add obviously since they are positive trims and scale the cruising trims by 4. Don't forget to smooth everything out so you don't have a jagged mountain looking maf scale.
    The trims aren't that bad fyi, i've seen worse. I don't know exactly how out they are when your idling since that's the max. I would definitely check for a vac. leak before you start messing with the tune though. It's not abnormal at all for the trims to be out that much, adding stuff throws everything off. When i moved my filter 5in closer to the maf my fuel trims went completely wacko. Just takes a little fine tuning and you'll be on your way back to wot tunes. And you'll enjoy the hell out of the headers.
  3. #3 Re: Jacked Up Fuel Trims w/Scan
    Outer Space
    One other member mentioned to me, that I could have a exhaust leak (which I believe, since its pacesetters) and fresh o2 could be getting to the o2 sensor.
    My MAP(kPa) looks similar to other scans, so I think its ok, but I will double check all vac lines to be sure.
    Thanks for the post!
  4. #4 Re: Jacked Up Fuel Trims w/Scan
    Outer Space
    Welded the pacesetters, fixed a small egr plate leak... reset trims.... still reading +16 on idle.
    Next we plugged the exhaust to see if it would get richer... it did not.
    The o2 sensor has already been changed once... and I do have a zzp extension harness.
    Any ideas or suggestions?
  5. #5 Re: Jacked Up Fuel Trims w/Scan
    Barksdale AFB, LA
    You've still got a vacuum leak somewhere.
    Or... have you looked at this (not sure if it applies to you)? Do you have your rear O2 deleted?
    http://www.grandprixforums.net/f65/r...ewer-7092.html
    2009 Subaru Impreza WRX STI
  6. #6 Re: Jacked Up Fuel Trims w/Scan
    Outer Space
    Thanks for the post... I have a rear o2 sim, not deleted.
    Another member pointed me here.... they call it the "16.4 Club"
    Odd LTFT behavior on 01 GS - HP Tuners Bulletin Board
  7. #7 Re: Jacked Up Fuel Trims w/Scan
    TDCRacing
    Guest
    Quote Originally Posted by Lawngoose View Post
    Hold on....they told me that only works for the o4 plus models....
  8. #8 Re: Jacked Up Fuel Trims w/Scan
    Outer Space
    Interesting.... that may be it. I am emailing them now.
    EDIT: Got a reply back from ZZP, they advised me that the o2 extension I bought for my front o2 sensor will work.
  1. Aeroforce Scan Gauge
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2013, 01:39 AM
  2. VE Tuning and Reseting Fuel Trims
    By JoshMcMadMac in forum PCM Tuning
    Last Post: 07-07-2008, 01:34 AM
  3. help with scan
    By ldyzluvdis06 in forum Midwest
    Last Post: 06-01-2008, 09:05 PM
  4. Last nights scan
    By Fish in forum PCM Tuning
    Last Post: 04-28-2008, 08:29 AM
  5. KR/scan tool
    By ldyzluvdis06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2008, 10:24 PM
