Thread: Ordering PCM from 3800 need a little help.
Results 1 to 5 of 5
  1. #1 Ordering PCM from 3800 need a little help.
    Feb 2013
    Ohio
    I have a 2002 GTP, 40 anniversary 85,000 miles cat back stock exhaust.This is what Im adding, JMB intake,catless down pipe,PCM, Autolite 104 Plugs, 3.5 pulley. The catless down pipe I assume there are two 02 sensors ? and I would need the down pipe to have the forward bung for 02 and delete the later one ? The PCM I assume I want stock egr,stock evap,stock gears. What do these engines like in the custom tune or standard ? random missfire stock or disable ? timing stock or + 3 degrees ? Thank you for your time.
  2. #2 Re: Ordering PCM from 3800 need a little help.
    Don't delete the rear o2.
    It's needed for cat diagnostics in your car.
    I don't think you know what's going on there at the end...but you aren't cammed, so you don't need to disable the P0300 random misfire code. The timing table isn't changed much in canned tune, IIRC...so you need to run at least 91 octane when you run these tunes...hopefully you are already doing so, stock.
    You live in Ohio, I'd drive to PRJ and have him tune it or find a local that can.
    Custom tune > Canned tune.
  3. #3 Re: Ordering PCM from 3800 need a little help.
    Feb 2013
    Ohio
    So your saying the rear 02 sensor will be ok with my catless down pipe right ? As for not knowing whats going on IMm just taking the info from 3800 site to order a pcm. Who is PRJ ?where is he located ? thanks.
  4. #4 Re: Ordering PCM from 3800 need a little help.
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    Prj lives in Indiana by indy has really good tunes and knows his stuff
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  5. #5 Re: Ordering PCM from 3800 need a little help.
    dyno brian lives in columbus if that's closer for you.
  1. Ordering a new silverado
    By cleaningman94 in forum Off Topic Discussion
    Last Post: 09-23-2012, 11:30 PM
  2. Ordering headers.. What else do I need?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2010, 06:39 PM
  3. ordering my 3" dp
    By boosting98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 04:10 PM
  4. web site ordering....
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-19-2008, 08:43 AM
