Thread: Tuner near SW michigan or SE michigan
Results 1 to 2 of 2
  1. #1 Tuner near SW michigan or SE michigan
    Mar 2013
    Dearborn
    1993 Bonneville SSEi, S2 L67 retrofit, recently installed the NIC cam. Have a bung for a wideband installed at the rear collector.
    Was originally planning on going to ZZP for the tune, but they cost a lot and I'm still doing some other mods that will throw off the tune (Fabbing a hood scoop CAI and plan to pulley down). Some things I think I really need to get set are the idle, disable torque management, and get a baseline on the fuel trims and timing, and maybe remove the SES for a code or two (those kind of things). Before the cam install, I was getting about 5lbs of boost at 3k-5k, with a jump to 7lbs just before the shift; intake and exhaust are P&P. Not sure I'm safe to go WOT before I get a baseline tune or I'd have those boost numbers.
    Anybody in SW or SE michigan that knows how to tune with the NIC? I wouldn't be opposed to learning to tune either, but not interested in spending $500 to deal with the HPT extra tokens I won't ever use unless I get the itch to convert a '93 L67 to OBD2 (in which case I'd unlock all '98 bonneville pcms and use that for both, but that car needs...work...).
    Also, any additional provisions I need (dynamat the knock sensor or trans case, etc?)?
    TIA
    1986 LeSabre Limited - was L67 powered, gone
    1993 Bonneville SSEi - ST5, parallel twincharged, 6-speed manual, rear disc conversion, HID retrofits, intercooled, KYB AGX, F-body front brakes
  2. #2 Re: Tuner near SW michigan or SE michigan
    Feb 2009
    flintnasty MI
    I tune out of flint.
  1. Michigan Tuner
    By rperry435 in forum PCM Tuning
    Last Post: 01-13-2013, 07:26 PM
  2. need tuner in Michigan
    By str3etgl0w in forum Midwest
    Last Post: 06-02-2012, 10:18 PM
  3. Tuner In Michigan?
    By str3etgl0w in forum PCM Tuning
    Last Post: 09-16-2011, 07:38 AM
  4. new from michigan
    By trevman7879 in forum Introductions/Noob Questions
    Last Post: 02-04-2011, 09:19 PM
  5. hello from michigan
    By Danalba in forum Introductions/Noob Questions
    Last Post: 08-05-2010, 02:47 AM
