Thread: pcm change?
Results 1 to 20 of 23
  1. #1 pcm change?
    Aug 2012
    Nova Scotia
    Hey I just did a recent engine swap. A 99 grand prix gt engine 3800 into a 2000 grand prix gt 3800. If I put the pcm from the 99 into my 2000 will it work fine ? Or does it need resetting or anything?
  2. #2 Re: pcm change?
    99-02 PCM's are all the same...so yes. As long as it is still an L36 PCM it'll be fine.
  3. #3 Re: pcm change?
    Quincy, Mass
    Quote Originally Posted by blueguy91 View Post
    I thought it was 98-02 that were all the same. Although i wouldn't want to go with a year below my own unless I was going to program it.
    No more GP 04 Impala SS Indy:
  4. #4 Re: pcm change?
    Aug 2012
    Nova Scotia
    alright thanks because it runs rough and will shut off after 30 seconds and i was told it could be the pcm acting up. so i can just take the 99 pcm and swap it into mine and have no need to reset? just plug in play and go?
  5. #5 Re: pcm change?
    Sep 2011
    Copperas Cove, TEXAS
    Try the 99 and see what happens.
  6. #6 Re: pcm change?
    It's likely not the pcm.
  7. #7 Re: pcm change?
    Aug 2012
    Nova Scotia
    what do you think it is? because i dont have the header crossoverfully on it has a leak cuz i couldnt get it bolted on right.
  8. #8 Re: pcm change?
    you don't have the crossover on at all? No wonder it's running like ****.
  9. #9 Re: pcm change?
    Aug 2012
    Nova Scotia
    oh its on but not fully its only got three bolts because one of the threads wouldnt come up enough for me to put the 4th bolt on.
  10. #10 Re: pcm change?
    a leaky crossover pipe will make it run bad but it still should run.
  11. #11 Re: pcm change?
    Aug 2012
    Nova Scotia
    alright. thanks im just trying to figure out how to get that bolt up because there is no nut on it or anything its just a long bolt with a thread. any idea how to get that up through?
  12. #12 Re: pcm change?
    take a pic
  13. #13 Re: pcm change?
    Quincy, Mass
    Wait did you replace your plugs after the header install? Because I bet you cracked a plug.
  14. #14 Re: pcm change?
    Aug 2012
    Nova Scotia
    yep i cracked two plugs while doing it. LOL i replaced them though with ngk's and all cylinders are firing
  15. #15 Re: pcm change?
    Why don't people remove plugs when doing headers?
    I've yet to crack a plug with them sitting on the cowl.
  16. #16 Re: pcm change?
    Quincy, Mass
    Because the rest of us aren't billboost37
  17. #17 Re: pcm change?
    Aug 2012
    Nova Scotia
    Any idea how to get the bolt that coms up through that header piece that bolts into the header join pipe? I can't seen to get the pipe on all the way cuz I can't get a nut on it because the bolt won't come up far enough?
  18. #18 Re: pcm change?
    Are you trying to put the front or rear connection point together? Stock or some other exhaust? I'm confused by your description.
    Either way, I typically use the bolts for it or that came with it. If you start all the bolts before tightenting anything, it should go very easily.
  19. #19 Re: pcm change?
    Aug 2012
    Nova Scotia
    the headers crossover pipe is what im talking about
  20. #20 Re: pcm change?
    Quincy, Mass
    What brand headers are they?
  1. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  2. oil change for 06 GXP
    By DirtDog in forum General Tech Discussion
    Last Post: 11-27-2012, 05:41 PM
  3. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  4. Tranny Fluid - To change or not to change.
    By midrange in forum General Tech Discussion
    Last Post: 02-15-2012, 11:44 AM
  5. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
